RNMashups Posted January 18 Share Posted January 18 1988 Jeep Comanche 4.0L 2WD SWB 4.0L / Automatic / 2WD / OEM axles (Dana 35's?) / SWB Build date: I'll have to check this. I forgot to write it down. Current Location: Western New York Status: It runs and drives, but it is a project truck (my first ever project car). It's sitting at a relatives heated garage getting worked on when I can find the time! I want to keep it as original as possible. Nothing crazy. Just as clean as possible with a few upgrades to make it more comfortable to drive. Notes: It's a bare bones automatic Comanche as far as I know. It's got the bench seat, but I recently swapped that out for bucket seats. I believe the truck has been white this whole time, but it's been painted over a few times...and not well. The interior is the less common blue color which makes finding interior trim difficult. The floor pans were replaced with street signs by the previous owner as you can see. It gets the job done but I will probably try replacing them soon enough. I was told it was a farm truck for a little while and it was at this time it sustained its damage. The B-Pillar, rocker and passenger door have a big dent in it from a t-bone accident at slow speed. Luckily, there is no frame damage and the frame is shockingly clean for being in New York. It seemed like it had solid potential so I snagged it for 1,500 bucks last April. Current owner: Haven't transferred the title yet, but it'll be in my name and at a relatives house until I get it to where I want it. Then it'll come home with me. Link to comment Share on other sites More sharing options...
89 MJ Posted January 19 Share Posted January 19 On 1/18/2025 at 8:26 AM, RNMashups said: The interior is the less common blue color which makes finding interior trim difficult. The floor pans were replaced with street signs by the previous owner as you can see. It gets the job done but I will probably try replacing them soon enough. Yes, Navy is a complete pain to try to find parts for. I've been searching for a set of Navy buckets for a couple of years. It was an 88-89 only interior color, I believe. I think replacing the floors correctly is definitely the way to go. Link to comment Share on other sites More sharing options...
RNMashups Posted January 20 Author Share Posted January 20 @89 MJ I may have to try painting a different color trim. That's assuming I can get the navy blue color (or something similar) that actually works well. It seems the posts I've read about painting trim have mixed results. I'm not a welder, so I was going to leave the floors alone. But now I'm thinking I can use 3M body panel adhesive and rivets on a new floor pan and not regret it. Link to comment Share on other sites More sharing options...
89 MJ Posted January 20 Share Posted January 20 42 minutes ago, RNMashups said: @89 MJ I may have to try painting a different color trim. That's assuming I can get the navy blue color (or something similar) that actually works well. It seems the posts I've read about painting trim have mixed results. I'm not a welder, so I was going to leave the floors alone. But now I'm thinking I can use 3M body panel adhesive and rivets on a new floor pan and not regret it. You can dye other interior pieces to match. I dyed a grey dash in my truck to match 3 years ago and its held up beautifully. I used SEM and a spray gun, but you can do aerosols as well. Here is a picture of my dye information Looks like the color code is 88P5: Here is a thread about the names of each of the colors and matching SEM dye in aerosol: And your idea with using 3M panel bond has been done. Be sure to use Key Parts floor pans, as they seem to fit the best. Here is a thread on doing that: Link to comment Share on other sites More sharing options...
RNMashups Posted January 22 Author Share Posted January 22 Thanks for the SEM info. That will definitely help in the future. I've already purchased a KeyParts cab corner for the passenger side damage. It definitely felt well made when I got it. Now I just gotta save up for those floor pans. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 23 Share Posted January 23 23 minutes ago, RNMashups said: Now I just gotta save up for those floor pans. Washers and dryers are your friend for floor metal if your in a financial bind. Link to comment Share on other sites More sharing options...
RNMashups Posted January 26 Author Share Posted January 26 Hey, not a bad idea if I get frustrated enough! Am I supposed to tag someone to see if they can find the details on my VIN? Link to comment Share on other sites More sharing options...
89 MJ Posted January 26 Share Posted January 26 6 minutes ago, RNMashups said: Hey, not a bad idea if I get frustrated enough! Am I supposed to tag someone to see if they can find the details on my VIN? It usually takes a few days for the members that are able to run the VINs to see these. @jdog, @JMO413 Link to comment Share on other sites More sharing options...
jdog Posted January 27 Share Posted January 27 Noted, probably be a couple days before I can get to them Link to comment Share on other sites More sharing options...
JMO413 Posted January 27 Share Posted January 27 *B1 TRIM STYLE B1 - CLOTH &&&& VNL BENCH SEAT -Q8 AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DGS TRANSMISSION-4SPD. AUTO,AISIN WARNER ERB ENGINE - 4.0L I6 MPI GAS LMA HALOGEN HEADLAMPS MDA FRT LICENSE PLATE ATTACH REQUIRED NAA ESA W/CATALYST (EXC CALIF SYSTEM) PWB White QWB White SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Link to comment Share on other sites More sharing options...
JMO413 Posted January 27 Share Posted January 27 Build Date 10/20/87 Body model TL61 Link to comment Share on other sites More sharing options...
RNMashups Posted January 27 Author Share Posted January 27 Thank you for any and all info, guys! Link to comment Share on other sites More sharing options...
RNMashups Posted April 7 Author Share Posted April 7 @fiatslug87 I think you missed adding mine to the registry this past round so figured I'd tag you for next time! Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 8 Share Posted April 8 @JMO413 or @jdog Can we get the selling location for this one? Thanks @RNMashups you're in now, thanks for checking. Link to comment Share on other sites More sharing options...
jdog Posted April 8 Share Posted April 8 LAZAR'S AUTO SALES, INC PEEKSKILL, Ny Link to comment Share on other sites More sharing options...
RNMashups Posted April 8 Author Share Posted April 8 Wow, checking google street view and the dealer is still there (although it's a collection of muffler and tire shops now). The one banner still has "Lazar's Auto" on it, though. Crazy! Thanks a lot for the information! Link to comment Share on other sites More sharing options...
