Another 1987 Comanche saved from doom. Project TALOS
This is the start of the thread for a project I began last year.
I picked up this stripped down shell with a title. Essentially all it had was a blown up 4cyl 4spd 2wd, steering column, back window, front dummy axle, and a hood.
I have been using an entire 1994 XJ 4.0 ax15 231 as the donor to rebuild this truck into my winter daily/back up wheeler/yard work horse. To take the place of a 1998 XJ I sold.
AF70F3AA-1099-4082-A7DE-A3ACE2240B8C.jpeg.1c9c73c339f21dd4512e87a7fe52a75d.jpeg3271D9BA-BD67-40AB-981C-4D4C40D535E1.jpeg.548cd1ea9730c02a3d4805bcbf438587.jpeg43ACBD3A-442F-4354-8743-DF79ADDA8683.jpeg.341a4c091f81387e6ddbadf926529bc0.jpeg
After I labeled pin outs for  the xj dash wiring and mj body harness I made an adapter to plug the xj dash into the mj body harness before I could start assembling the interior.
Got a brand new windshield installed with the rubber gasket.
I acquired all the MJ specific interior trim etc and carpet from the same person I bought the shell from. We converse on a regular basis about Jeeps lol. Kinda how I ended up with this in the first place.
I installed all interior, xj e brake and center console, Laredo buckets, b pillar speakers, installed vw beetle down lights into the b pillars. Azzy gauge faces, a random radio I had,  as well as silver dash bezel. I did also modify xj seat belts to work as I didn’t have mj ones.
324C9B60-4DAF-437F-AA8A-A78DF9661679.jpeg.6b1f4a69d2c6d2a343219a4ef6e155fb.jpegCFC83B16-7C9A-4ADD-BF25-638E02443A28.jpeg.4374ab940c96eb3cab5db47d63849f47.jpeg69D83EAC-1A70-4707-B881-BAD7B726DB54.jpeg.328dd6ce0fa6c9d84c4e023716ec72ee.jpegDC021090-5266-4B0C-8124-9863F6081A21.jpeg.3681345007d81824db44884af9136fe9.jpeg43FB003D-6541-48EB-AD17-BAF9125815E2.jpeg.d713d40c85a616e85125892d6486e494.jpegA0BC9DB4-F32B-496E-ACFF-D1AC68921D8A.jpeg.cf176cbb1d0c2df118d8728e82778f29.jpegD9D2E9CF-FBB8-4678-A9ED-F89C0DFDC896.jpeg.0a776b86aafb09ad89a964df19fea503.jpeg564A9197-2C65-4BD8-B04E-F5AF0FEAE45A.jpeg.93c571dce23548e74a66a0ed99341f4d.jpeg
Got a junk roller from a friend for the 3.55 axles. I had to straighten passenger LCA mount as well as repair the passenger coil bucket. I made a UCA stiffener and replaced both upper bushings. Welded on some Barnes LCA skids. Added some iron rock bump stops. Swapped the axle in.
During this I installed a brand new steering box and a used jcr spacer and the bumper tie in plate.
995A028D-5E92-4658-B912-5B8E233E6C4F.jpeg.31022812c816cd9b705dc8e1390e93a3.jpeg81FF4D5F-3F7C-4645-839E-544EC393461B.jpeg.05b1ca62549509a88b7025b7ab3205d0.jpegEBBCC7A4-7A9A-4BA1-BF12-EE084B4BDE19.jpeg.ff00ab9349d408035697f629ddfee2c9.jpeg837D1D48-F7F0-4D5E-B3BB-F21A8D26CD7E.jpeg.fedc9972a4d161a4585af09a266be912.jpeg63093256-5BD1-43A9-8CF8-4DF3B694579A.jpeg.4968c26c50cdd7db96907ea8905587fe.jpeg
Every hard brake line was replaced with stainless kit and then some. Most the old lines were all gone already. Replaced all the fuel line and fuel filter, replaced the gas tank as it was rotted which allowed me to toss the 94 xj sender in.
CA15AC69-367D-4673-87AE-33FEAD706524.jpeg.ee0c5ae59235588420ade16b5cc901c4.jpeg60D583D1-3512-419C-B922-E5B403DFFFA3.jpeg.82754b79c832a18ae7fa96c108ea7d94.jpeg
Started 8.25 swap. Cut all old brackets off.
mocked it up under the truck after having to modify the incorrect spring perches I had ordered 🙃 I did the ubolt strap mod on the pinion. I welded shock mounts to the axle as I didn’t have any mj ubolt plates to use and figured this way I can get away with running stock shocks on 3” of lift. I replaced every single rear axle brake part and lines.
611B2529-5DCB-4B2A-AA28-B331ED32F07F.jpeg.bb07754694f07f05f3361de1142b482a.jpegE1155C18-EEED-42C2-92A2-6D2E9E7EBEB2.jpeg.cfa3fffe2298597ba3ae5919b65c5d48.jpegD77F606D-45A2-4850-BEAD-60C57A4C39B6.jpeg.a6badd549f734916c073a64a986538f6.jpeg56AC0755-2F45-4087-823B-CD61BFE856E4.jpeg.152c5cf51c74efe60a0814cba9267322.jpegAD5A9EE0-AB33-4B08-8422-8D0E7A86F7B9.jpeg.0babfd0c0217b0d229da601624496e58.jpegC280A62C-5CAF-422B-B460-F6D984141D3E.jpeg.2f5e3eea9a04a0ec1c9b8ed78084ceaf.jpegB7ACF179-3960-448D-8930-612759680AA3.jpeg.2608ca6c2b2298ad28c3bfaedc4cf051.jpeg
I have a 2wd manual xj rear driveshaft bolted in temporarily until I can get the mj shaft I have cut down  to length I need. The xj shaft is about 2” too short for comfort.
I put a tip on the tailpipe from Amazon because the stock of was all bent up and crusty so I just chopped it off and bolted the tip on.
This is about where I’m at with it now.
the wheels on it currently are temporarily until I get my tires mounted on some jk Willy’s wheels.
I have to continue bleeding the brake lines if not replacing the master cylinder, build some bumpers, repair the rockers, and repair areas of the bed. I’m planning to make my own bed armor to cover the Swiss cheese bed sides.
I haven’t been able to work on it in almost a week. Whole family got an awful stomach virus.
Before that happened I spent a couple hours patching up the bed behind the cab on the passenger side and I folded the cuts on the rear quartersD7D3A04D-9162-4D36-825C-D850A23E3320.jpeg.55b5602c2d1a78ef9a2974f8ede9aef1.jpeg3395B704-5E8A-4A32-AFF6-7BD5BCC41362.jpeg.68b718825511d0c74e6dbefaf1d93717.jpeg
On 1/14/2025 at 2:52 PM, Salvagedcircuit said:
Lookin good! :brows:
I should throw an 8.25 with discs under mine one day to replace the stock D35. one day...
Thanks. It was easier to just leave the drums for now. Maybe if I put a rear locker in it eventually I’ll do disc brakes at the same time
Yesterday I welded up my diy bumper I’ve had laying around and added my dirtbound tubes that showed up a week or two ago. Ground down the excess welds and started painting it to put back on soon.
I still need to try to bleed my brakes again or might have to replace the master cylinder.
I will start a home made cut and fold rear bumper soon as well.
9FC7544D-D0BC-4E00-ABD5-7C9FAC69DF30.jpeg.16fa35e46df139ffa98b678114dea6c1.jpegD14F563F-0B38-4117-9F33-7EB1BD441CE4.jpeg.d259787f22dc6818b117f33498f47792.jpegF688048E-7776-4002-A7E4-4B308E2E2AB5.jpeg.f6918226aad2d4bf413e16905c6fb961.jpeg5371ED2E-2348-4035-B87B-5582E15E3070.jpeg.e3e1c7c116276c6aa3965769a8983039.jpeg
Front bumper is finished and bolted on.
I started a rear bumper today from scratch. Still need to cut the corners and cap them otherwise I’m waiting for clevis mounts and receiver to show up to weld on and then paint. 7183960E-5EF6-4BB7-B067-C7B3B7BF7D13.jpeg.8a8476e75710dc40502591e2ffca43e9.jpeg3F360A19-BB33-464B-AE68-7C30D57B6690.jpeg.5c2390b54dc335b72069e989ddb66da9.jpeg4307C302-B730-462F-A96B-93E312C52A73.jpeg.05fd5a0831f892175728a953b6239edc.jpegFF1BE7E7-9857-4660-B05C-0B305F9033B6.jpeg.a00805bff073aecdb126f876ff92aedb.jpeg
On 1/18/2025 at 8:35 AM, pizzaman09 said:
This truck is coming together beautifully.  If you make it too nice you might not want to drive it in the winter.
It’s my beater work truck project still. I have another 87 mj that is my prized truck that is staying out of the salt.
21 hours ago, watchamakalit said:
Mine is far from "nice" but I still try hard to keep it out of the salt. I personally would advise anyone who wants to keep their mj indefinitely to do the same. And considering the time and parts invested I bet this one isn't going anywhere.
Yeah I have three other Jeeps that I’m keeping out of the salt. My other 1987 mj, 1998 xj trail rig, and 1996 2door xj
Currently working on patching up the holes in the rockers and cab corners. Today I got the driverside done.
My father stopped by to help me bleed my brakes and I’m pretty sure I’m going to have to replace the master cylinder. I have back pressure engine off but engine on the peddle is super soft and goes pretty far to the floor.
I did also install some aftermarket side markers. They’re decent, WAY more light than factory.
