70barracuda Posted December 22, 2024 Share Posted December 22, 2024 Anyone know if the 86-90 ignition lock cylinders work in a 91+ column? Bought a "new" tilt column and it's a 91+ with chrysler keys. I would like to use my original GM key if I can. Link to comment Share on other sites More sharing options...
pizzaman09 Posted December 22, 2024 Share Posted December 22, 2024 I don't know but it sounds like you have the parts at hand to find out for us! 😜 I kind of doubt it will be plug and play. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted December 22, 2024 Share Posted December 22, 2024 If memory serves, it’s a no. It has to with how it’s held into the column. The early cylinder uses a bolt to retain it, while the later cylinder uses a spring tab, which is not present on the early cylinder. I was able to make a 91+ cylinder fit into an ‘89 column by grinding a notch into the cylinder where the retainer bolt goes, and removing the spring tab. But I don’t think you could add the spring tab to the early cylinder to go the other way. You can see the slot on the far right of the Chrysler cylinder, that’s where the tab was. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 22, 2024 Share Posted December 22, 2024 On 12/22/2024 at 11:45 PM, GonzoTheGreat said: If memory serves, it’s a no. It has to with how it’s held into the column. The early cylinder uses a bolt to retain it, while the later cylinder uses a spring tab, which is not present on the early cylinder. I was able to make a 91+ cylinder fit into an ‘89 column by grinding a notch into the cylinder where the retainer bolt goes, and removing the spring tab. But I don’t think you could add the spring tab to the early cylinder to go the other way. You can see the slot on the far right of the Chrysler cylinder, that’s where the tab was. Expand This reminds me of my 84 where it doesn’t have the bolt to keep it in place but it has a spring tab on the lock to keep it in place. Link to comment Share on other sites More sharing options...
jpnjake Posted December 23, 2024 Share Posted December 23, 2024 My Dad did this swap last night on the 91' XJ, he had both early, and late lock cylinders. Before (Chrysler key) : . After (GM/AMC Key) : Lock Cylinder he removed: He was surprised the 91' column took the early lock cylinder (WellsA08004) Link to comment Share on other sites More sharing options...
70barracuda Posted December 23, 2024 Author Share Posted December 23, 2024 Do the 91+ door lock cylinders fit without much work? I was thinking about it and one key would be kind of nicer. Link to comment Share on other sites More sharing options...
jdog Posted December 24, 2024 Share Posted December 24, 2024 On 12/23/2024 at 6:31 PM, 70barracuda said: Do the 91+ door lock cylinders fit without much work? I was thinking about it and one key would be kind of nicer. Expand Yes, I've done it to both my jeeps, just don't forget the glove box lock. Link to comment Share on other sites More sharing options...
70barracuda Posted January 2 Author Share Posted January 2 The older lock cylinders will fit the new chrylser column. The retainer pin/bolt will fit to hold the cylinder. Link to comment Share on other sites More sharing options...
