Project: Slippery Slope – a ’91 MJ runner
Gjeep
Goodbye load sensing valve setup – this MJ gets an XJ combination valve and loses the hardline that manages the rear axle valve. I’ve never liked the balance in braking that the factory MJ setup had. I swapped over to this set up on my other MJ and ran it 150K without issue/ lockup around the crazy roads and drivers of California for years. World of difference and confidence. Once I swap the front axle swap, cross drilled rotors and new braking components will complete this stopping power metamorphosis.
  • Replies 218
Although not completely done, I got the XJ hand brake cable/ bracket in place and connected it to the MJ parking brake splitter. To support the hand brake under the MJ floor pan I drilled out an XJ backside bracket. It stiffens the floor up well.
I also installed the newer style CPS (’93-’95) and couldn’t be happier with the amount of distance it provided to keep that wiring away from the header. I needed to swap the connector as the pins are inline versus triangular as in the ‘91/’92 CPS. The wiring itself is now pressed up against the firewall, behind a brake line to keep it from moving. This era CPS with its longer connector provides an extra 1.5” of length. When removing the old CPS, which was original no doubt as bolts were unscathed, I was surprised to see there was no grommet in the bell housing for it to reside in.
Always an adventure. What I though was going to be a reasonably quick change of gasket turned into a trying of patience. PO (or I’d guess PO’s mechanic) RTV’d the oil pan to the block almost 1/4” thick and it was on there. On there good.  Lost count how many times I walked away from it. I ended up bending up the oil pan lip so much that I ordered a new one from Mopar. Front side of the pan had a thin gasket strip that I’ve never seen and no RTV. Oil was coming out regularly in this spot – mainly because the RTV was on so thick. Front side had this thin gasket or old gasket scrap that was 1/8” thinner than the rest of the junk. Crazy. On to changing rear main seal; then FelPro gasket on the pan.
Been a while since I’ve looked under a 4.0L and saw it withOUT girdle.
A stamped steel 4.0L valve cover is going on with a new FelPro gasket and New Comer Racing billet bolt grommet retainers. I had good luck having swapped this cover onto my other MJ long ago. No more oil-soaked air filer. This cover has new CCV and PCV elbows and grommets also.
Lastly, I installed the ’95 XJ dual diaphragm booster and bent up lines to the new XJ combo valve. This calls for a mix of standard flare and bubble flaring at the master cylinder. I’ll be placing the bottle jack and related tools under the hood like my other MJ.
Cutting, bending, shaping is what I’ve been up to – Forgot that changing over to the newer style belt tensioner means cutting off the boss that was once used with a probe to read timing back in the day. (Could have used the newer timing chain cover, but the harmonic balancer is already on…)
Also, the under the hood jack bracket was shaped into something that works for the MJ. Needed to redo one of the master to combo brake lines to accommodate the location. This build I’ll be using the MJ versus XJ jack ‘crank’ (as done on my other build for fitment). MJ crank is obviously longer. All will be cleaned up and painted, but same idea applied this round with the Ford jack related clips. Clears the hood prop rod when in the lowered position, so all is good.
Good times disconnecting the front side brake line – I soaked them, heated them, and still couldn’t get the passenger side off with out absolute destruction. Fortunately, Jeep provided enough line that I was able to put another nut on a flare.
And front axle is out. This MJ will remain 2WD, but I’m upgrading to the axle/ends that accept hubs versus the greaseable bearings. Again, just keeping components consistent with the other Jeeps in the herd. New ZJ steering linkage/ V8 sway bar, Mopar hubs, cross-drilled rotors, calipers, coils, brake lines, etc will be installed as it goes back together. I want the front end to be brand spankin new. I went with OME heavy-duty coils that will raise the nose ever so slightly. KYB MonoMax shocks will be installed all around.
Always fun waiting on parts to move forward, but I’ve been chipping away at little things engine bay – got the jack set up cleaned up and installed under the hood, distributor wires in, bored TB and NOS Mopar related sensors, various broken connectors replaced, and I forget what else.
Landed a SB MJ camper shell that was removed a year after the truck was purchased new. Thankfully, its been stored inside for past 30+ years. Original owner and he still has the truck. Will introduce him to CC and see if he joins. It’s a 20 hour round trip but anything MJ worth it. I won’t be running the shell full-time, only as needed.
The journey was good and the SnugTop made it home. On the way back, I stopped at a handful of wrecking yard to get various hardware for this build.
Long live New Comer Racing – those billet grommets for the 96+ valve cover are beautiful. Going to get them for all the XJ’s. With those in-hand, I was able to get the new valve cover on, cables crossed over to the TB, breather lines, and heater core hoses in place. For the heater core/ hose setup, I eliminated the plastic valve of this 4.0L generation. Just straight hoses to the heater core.
Having a heck of a time getting the upper portion of the rear main seal out. It’s stuck. Tried what feels like endless approaches – too much fun. Needed to walk away from it, so I don’t set fire to the Comanche. Will circle back on this fun…
Decided it was time to have a look at the NOS automatic steering column that’s been tucked away for a bit. Was happy to find it’s a tilt column and all I need to fish through is the cruise control wiring as part of the stalk install. Only other thing to do is swap out the ignition cylinder. This is a later Renix era column so the ignition switch is oriented in one direction as compared to the HO years which is flipped the other way. I also found a NOS parking brake interlock kit that will be added to the mix.
Next, I tackled the AC install engine bay side. Again, I’m going with the factory ‘94.5-‘96 R134 XJ set up. Got the drier and condenser into place and attached the related lines. Once I brought the radiator into the mix, I realized I’d have to use the old upper radiator horizontal support on the new radiator as it had integrated AC condenser bracketry tied into it. A cleaner install. No where near ready to charge as I still have the HVAC box out.
I ran into the same problem when I did the rear main on my Eagle with the 4.0. I ended up breaking loose the crank main bearing caps then I was able to get it out. If you do this make sure to retorque the bearing caps before the oil pan goes back on.
I haven’t been this happy since my kids were born. Endless days/ hours to get this rms out. It was ridiculous. And the old one that came out was hard as a rock. To be honest, I thought about throwing in the towel and gasket-maker-ing the hell out of this area. Insane. Insane, and finally done. New rms in place and time torque retaining bolts and get the oil pan back on – using a gasket. Surprised I don’t need therapy dealing with all this bottom end of the engine crazy.
Thank you to my friends over the past many days who made this possible.
After replacing the rear main seal, and new to me AW4 cover plate (original was bent), a new FelPro oil pan gasket and Mopar oil pan were installed. The AW4 transmission cooler lines were run/ connected and a NOS electric fan was installed. This truck didn’t have an efan originally as it was a non-AC truck.
Engine almost buttoned up... need to finish up HVAC install/ charge the system and done.
I was hoping to line up the ’98 XJ axle and get it bolted up, but somehow missed the torn clear to the other side rubber bushing. Must have looked at one side but not the other – on order, 2 new bushings. In the meantime, I went ahead and installed the Moog replacement UCA and LCA’s.
Next up is dropping/ cleaning out the fuel tank and replacing the pump with a new Bosch unit. While in there, a new filter will be installed pump side, along with new hoses and proper fuel clamps up to the hard lines. The inline filter under the cab I replaced a few weeks back. Once that’s done, a factory short bed skid plate will be installed.
Pressed out the old, torn front axle LCA bushings and pressed in new Mopar units. Soon to get the axle up and will install new springs, the usual cross drilled rotors, calipers and HD ZJ front end tie rods and sway bar.
New Denso starter in place; and like all the other Jeep’s in the family, this MJ was converted to the newer style/ connector starter (battery cable not connected yet).
Finally, NOS Marchal driving lights were taken apart and cleaned up (there’s always a haze on the inside of the glass). I’ll be running those on the front end of this MJ because the road to our house from town has zero lights and plenty of deer and wild turkey.
Progress – getting that oil pan up made a world of difference being able to move forward. I was able to get the front axle placed and ends torn apart. It's getting all new everything. Peace of mind.
And again, for those of you with a 2WD MJ’s, the ‘93+ XJ’s use the same unit bearings as the 4WD’s, meaning you’ll have easy to source replacement brake parts, thanks to this dummy shaft insert.
Service time for the AW4 – the previous owner had a shop service the transmission a year back, but I had absolutely no faith. I dropped the pan and cleaned inside/ out and found no cause for alarm around the drain magnet. A new Mopar filter and FelPro pan gasket have been installed and transmission filled with Motul Dexron III ATF.
New ball joints, hubs, rotors, calipers, pads, brake lines, springs, shocks, and sway bar endlinks installed.
Removed the old fuel pump and installed a new Bosch unit, running a new fuel filter and line. Nutserts in place and shortly the skid plate will be in place.
It’s in the 40’s here in Oregon, up from the 30’s last week – and that temperature is no friend to paint. So, the wife mentioned she wanted to visit a friend in California and I was all over it. Spa, flight out… I have the house inside just about 70 degrees and painting a few panels and trim that need freshening. It's a mix a NOS and used, so I want to make sure all is uniform in color. I still need to notch the air dam for tow hooks and will refinish that once it is done, but that’s couple weeks away. Black interior panels will get a good scrub though I’m not going to refinish them as this is a runner. A work truck…
I was dreading removing the year and half old headliner. Fresh glue, fresh foam. I tried tugging on it in a small area and foam stayed while material peeled off. Did some research and found a YouTube video of an upholsterer who was advising to use a wire brush on a drill at half speed, spinning it in reverse up until you get to the corners – and this would work for all types of headliner composition. I read through the comments of the video, and they were all positive. I noticed my headliner was skimmed with bondo so I thought I’d give it a try. It worked and caused no damage (I slowed way down around the visor openings and corners). Never would have guessed. It worked on the backside of the board also where the headliner material/foam was wrapped over. And again, the wire brush caused no damage. Live and learn…
Installed the fuel tank skid. A lot easier doing on a lifted MJ, but got it done. This is the same skid plate I originally had on my ’92 so it was in good shape and ready to mount. Still need to sort and secure the wiring.
The prior owner had an Eaton locker installed somewhere along the line. Time for service, so cleaning out the diff and will be installing a Lube Locker gasket and the usual stainless steel bolts for bling.
Time to cut the Comanche’s headliner for overhead console clearance. Similar to my other MJ build, I’m using a modified first gen XJ overhead console with reshaped mounting bracket front side and adapted SJ bracket in the rear. As most know, the XJ roof line is for the most part flat, while the MJ’s rises to the rear. Black outline on this headliner marks the standard XJ headliner with overhead console cut and the balance is what needs to clear and sink the MJ console creation into place.
Cut down the mid-90’s Ford combo brake and cargo light flat all around to match the central location I’ll be mounting on MJ – similar to where the factory Jeep cargo light is mounted. I had to take off close to 1/2” at the widest location of the plastic surround. The light assembly has a raised seam backside that goes all the way around to two drain holes bottom left and right corner. So long as I mount it in the right spot, I should clear the light socket inserts and have about 1/8” between the cab sheet metal and the inner support bracket.
Shuffling my feet towards the finish line – Got the front axle installed and what do you know, it’s near dead level front to rear. Actually 1/2" higher in from. I prefer my trucks have a slight rake. So, I ordered metric ton leafs and XJ shackles (if I need to go there)… as I’m aiming for about 1.5” difference. (Yes I could do an add-a-leaf, taller shackles, or several other methods, but metric tons it is.) While I’m playing at the rear axle, going to dive deep into the drums, wheel cylinders, etc. New as new.
Also been chipping away at readying the new shoulder belts. Since I’m swapping over to a black interior, I’m installing the same belt set up as I did my other MJ. XJ belts is all you can get, but with a couple hours of work you can swap that shoulder belt assembly over to a modified MJ bracket. I learned first round that the ’86 and ’87 brackets work best with the new belt assembly. It’s a completely different mounting bracket than later year MJ’s and requires less work to get right. Flat black paint is drying overnight, ready for assembly first thing in the morning.
Lastly, I unearthed one of my spare black dashboards and cleaned it up. This one came from my ’86 XLS long bed parts truck I bought, stripped and sold years back. The kids called it “The Beast” and all took turns learning to drive stick on it. The dashboard of that truck, as the rest of the interior panels, was in great condition but absolutely filthy. I could hear there was something sliding around in the air passage that took a bit to get in a corner where I could see it – finally found spotted – a long since abandoned hive. Bet that truck was a real party when the blower motor kicked in. Interior panels scrubbed as well and looking like new.
Since I have my jack items under the hood, my carpet panel at the backwall can be clean. Once I drilled/ removed all the hardware from the old cardboard, I trimmed a some masonite to size, marked hole locations, and attached the original hardware with screw/nut retainers (since I dislike rivets).
