Intermittent cutout/studder right off idle.
Hello all, my Jeep has developed the interesting quirk of a very intermittent issue where the engine falls on its face while under very light throttle inputs. If I give it more gas, it’ll rev up no problem, or if I go back to idle it’ll idle fine. I deleted the EGR believing it was the problem however it has remained afterwards. TPS maybe?
  On 10/14/2024 at 2:23 AM, M.T.Hands said:
Man, off idle like that sounds like something "dirty" with the Idle circuit, I'm very new to this vehicle, but my 04 wrangler had a messed up TPS and it would not idle:dunno: but definitely could be vacuum or fuel pressure related
Expand
My idle circuit isn’t working properly so I have it disconnected. It’s been that way for ~2 years now.
  On 10/15/2024 at 10:22 PM, Ωhm said:
O2 (V) seems frozen at idle. Should switch rapidly between 0.5 and 4.5. Rapidly like at the speed of light. Coolant sensor is trashed, or wire is your problem.
Expand
It’s in open loop, if that makes any difference. Very rarely does it ever enter closed loop. Wires looked fine going to the sensor. It’s a pretty cheap old thing, so it’s probably that coolant sensor itself that’s bad.
  On 10/15/2024 at 10:24 PM, Ωhm said:
With that O2 and maybe that Coolant sensor, it can't go into Closed Loop.
Expand
Even with it running ok it’s almost never entered closed loop. I almost wonder if the computer isn’t faulty a little bit. Ive used it fine without it entering closed loop but having the iac disconnected is a bit annoying when it’s cold.
  On 10/15/2024 at 10:33 PM, Ωhm said:
Sound to me like the ECU is doing what it's supposed to do. Open Loop.
Expand
Now that I’m thinking on it more, I think it’s that O2 sensor. I was trying to delete my EGR valve and when I removed it I dropped it (about 3-4”) so I almost wonder if that didn’t break it. I don’t believe I remember feeling the issue before then, so it makes the most sense to me now.
  On 10/15/2024 at 10:48 PM, Ωhm said:
Key OFF. Disconnect O2S. At the sensor measure ohms between C229_A and C229_B. Look for 5-7 ohms.
If good, then signal side of sensor is bad because it's just not switching at idle.
Expand
I am showing 0 (or near 0) ohms between A & B. About 4 between C and B.
