Mud flap size?
On 8/23/2024 at 10:10 PM, Eagle_SX4 said:
Thanks @fiatslug87 I am probably going to buy some of these and cut them up to fit.61oh6AeM5pL._AC_UF894,1000_QL80_.jpg
https://www.amazon.com/Plasticolor-000542R01-JEEP-MUD-GUARD/dp/B0794CDQ2K
They are 11x19 which is pretty close to the overall size and should work better for my 31x10.5 tires.
I think this is your best bet. The OEM mudflaps are too small and dinky looking for a lifted rig with tall tires, and they don't hang low enough to the ground to be functional.
1 hour ago, Eagle_SX4 said:
Got the new mud flaps in the mail. I had to add the missing detail.IMG_20240829_160126552.jpg.8988bac2e8da7401303d12c041a83420.jpg
It is some white adhesive silicone tape. It's supposed to be used as a non slip tape for furniture.
I'm following this build thread with some eager eyes. Stainless mudguard brackets from @boxyjeep looking good in the cart....
:popcorn:
After a quick mock up I found I won't be able to use the factory style brackets. I will have to make my own. I am going to mount them much lower in the front than the factory ones were.
Approximate factory locationIMG_20240831_100855491.jpg.c1d9afa95ab9e659e13b210352ab6902.jpg
Where I want to put themIMG_20240831_100904250.jpg.a398237bf8367c5839c0360c3ef82395.jpg
To be honest, the front factory brackets leave a lot to be desired.  One side is just a long screw with plastic standoffs into the fender liner.  I'd strongly recommend doing something like one of our other members did where they built a bracket between the fender mount and inner body.
  • 4 weeks later...
Well I got the passenger side bracket made. It is stainless and I think it will work well.IMG_20240926_203457398.jpg.18d2bb3a6f34aa77ffbc219ed728910a.jpg
The outside resembles the factory bracket with a leg that goes over to the body and get held in place by the existing body clip that holds the inner fender liner in place. It is all one piece.
