Strokermjcomanche Posted Thursday at 11:19 AM Share Posted Thursday at 11:19 AM What’s a good upgraded radiator? I just recently got done installing my 4.6 stroker in my essentially 95 swapped Comanche. Everything was new including the radiator when I installed it a few weeks ago. It has been running hot and I have gone through the timing an air to fuel ratio and they are both good. Also changed fan clutch and that didn’t help either . I’m looking for a radiator that I can put in once and not have to deal with again. I have read through a lot of reviews on a lot of radiators and can’t seem to find one that has nearly all positive reviews, most of them only lasts either a couple months or a couple years. I’ve had good luck with the spectra and Murray radiators for my stock applications, but it’s not doing the job on this truck . Anybody have any advice? Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted Thursday at 11:21 AM Author Share Posted Thursday at 11:21 AM I should add that I do have a MishiMoto radiator, but after reading those reviews I’m not even sure I want to put it in. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted Thursday at 12:01 PM Share Posted Thursday at 12:01 PM Mishimoto hands down unless you can fit a Novak core. Cold case is another good option. Keep in mind that so called “high flow” pumps and “high flow” tstat housings can be the culprits of many cooling issues. Stock pump, 7 blade mech fan and the late model 10 blade XJ fan (the oem Mopar one) with a good 30-40A power supply will keep it cool. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted Thursday at 12:58 PM Author Share Posted Thursday at 12:58 PM I have the Mopar fan, just a plain Jane GMB water pump, the Mopar clutch fan. I’m aware of the high flow water pumps, but I do have the new comer thermostat housing.What are the issues with that? I don’t care if I have to change something else Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted Thursday at 02:53 PM Author Share Posted Thursday at 02:53 PM Link to comment Share on other sites More sharing options...
pizzaman09 Posted Thursday at 03:25 PM Share Posted Thursday at 03:25 PM I run Mishimoto radiators in my BMWs and love them. I would run one in my Comanche if I needed a radiator. Link to comment Share on other sites More sharing options...
derf Posted Thursday at 03:27 PM Share Posted Thursday at 03:27 PM I hear second and third hand talk about the Mishimoto but I can't find too many actual failures. Just a bunch of "I heard they aren't good" posts with not much first hand experience. So I have a Mishimoto getting ready to go into my truggy project with a stroker. I'm still debating whether to use a high flow water pump or not. And I'm going to go with the triple electric fans, mostly because I'll be doing low speed crawling where the mechanical fan won't be up to full speed most of the time. Link to comment Share on other sites More sharing options...
89 MJ Posted Thursday at 09:54 PM Share Posted Thursday at 09:54 PM 6 hours ago, derf said: So I have a Mishimoto getting ready to go into my truggy project with a stroker. I'm still debating whether to use a high flow water pump or not. And I'm going to go with the triple electric fans, mostly because I'll be doing low speed crawling where the mechanical fan won't be up to full speed most of the time. I think I’d run a high flow then. I think I’ll do the same on my truck. There seems to be a point where these trucks turn too many rpm to stay cool at a certain speed. Even with everything functioning correctly, my truck overheats after a couple of hours running 75+. I like the Mishimoto in my truck. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted Thursday at 10:39 PM Author Share Posted Thursday at 10:39 PM All right I guess I’ll throw the Mishi Moto at it. Have to wait for the stupid overflow nipple That they say is included but it’s not. I will update with the results. Thanks everyone Link to comment Share on other sites More sharing options...
pizzaman09 Posted Saturday at 04:09 PM Share Posted Saturday at 04:09 PM On 6/27/2024 at 11:27 AM, derf said: I hear second and third hand talk about the Mishimoto but I can't find too many actual failures. Just a bunch of "I heard they aren't good" posts with not much first hand experience. So I have a Mishimoto getting ready to go into my truggy project with a stroker. I'm still debating whether to use a high flow water pump or not. And I'm going to go with the triple electric fans, mostly because I'll be doing low speed crawling where the mechanical fan won't be up to full speed most of the time. I've had a Mishimoto leak on my one BMW, but it was not the radiator's fault, it clearly had taken damage from something hitting it. Link to comment Share on other sites More sharing options...
AZJeff Posted 11 hours ago Share Posted 11 hours ago I will be odd-man out here: I have run all-metal CSF versions in my previous XJ and now my MJ, and I live in S. AZ, so it’s a high stress environment. I have no issues. Link to comment Share on other sites More sharing options...
