Custom Gaskets for HVAC
  • Replies 54
52 minutes ago, AZJeff said:
I am interested in how these pan out.  What technology did you use to cut the foam?
I used a crayon to trace the openings onto a sheet of paper, scanned that to the computer, then traced the scan in CorelDraw. From there, I made an outline in the thickness I needed for each gasket (also on CorelDraw) and sent it over to our laser cutter to cut.
The laser cutter is the part I am most interested in.   Is this a tool you own?
Unfortunately I don't own it, they're quite expensive! It's at the library where I work.
That's too bad, because those samples you showed looked to be of OEM quality.
Don't get me wrong - I can use the machine whenever I so choose. I'm the head of our "MakerSpace" which has the laser etcher among other things. And thanks! I used 1" and 1/8" microcell polyethylene foam to make them. I'll be making some more (likely today) with improvements. It's rare to get it exactly right on the first attempt!
Have you tried reassembling the hvac to the firewall yet? 1" was too thick for the cowl opening for mine so i ended up with 3/4. "Minicell L200" foam is what I used and seemed to be identical to the oem stuff. Made some nice kneeling pads for working under the truck with the extra. That stuff also cuts excellent with an electric turkey carver.
Not yet! That won't come until after I finish sealing up the leaks and sound deadening the firewall. The tricky part is getting an exact replica of the OEM gaskets. After that I can easily cut them out in whatever thickness I need.
Any chance you have access to a water jet cutter? That would probably work well too.
I wish! About 15 minutes away is another MakerSpace with a $60/yr fee. They have one, along with all sorts of other neat tools.
26 minutes ago, eaglescout526 said:
God. just looking at your old ones makes me wonder how much cold air flow I am losing to the dash.
Lmao. Once I put the heater box back in and make sure everything fits I may gauge interest to see how many would purchase them. I think they'll fit all (or at least most) 96 or below Cherokees/Comanches.
I'd definitely be interested. They look awesome!
the cowl opening is a real bear to reproduce.  the old one is crazy flexy and the new foam has to be practically the exact right height to fit in there.  and it was still a real pain in the butt. :(
Thanks! Once I get the final fit I'll definitely post them up for others.
5 hours ago, Pete M said:
the cowl opening is a real bare to reproduce.  the old one is crazy flexy and the new foam has to be practically the exact right height to fit in there.  and it was still a real pain in the butt. :(
I'm definitely anticipating a Mk. 3. Lol. We'll see how it pans out when I try to put everything back in the truck!
19 hours ago, Duncan Moody said:
Nice work! I improvised with weather stripping, doublesided tape adhesive, and gardening kneeling pads! Not going to open it up and try again though. Hopefully never have to do that again.
Thanks! It's a huge pain to get off - I wrestled with the nuts and studs in the engine bay for about 10 hours!
