Aidenmoreno3 Posted January 16, 2024 Share Posted January 16, 2024 Aight so here we are again I've been doing research on the horn infamous horn problem however, my situation had a little bit of a twist When I bought the truck the previous owner had an alarm system hooked up to the factory horns and they worked, but the actual horn did not, only when the alarm went off. Eventually the alarm system stopped working altogether and with it went the horns. that alarm system turned out to be wired a little less than ideal and I was worried about a possible fire so I just payed someone to re do the whole thing. He installed one of those little chirp alarms that come with the kit and I was happy with the noise. problem is now I have no idea what wires were cut, or disconnected in order to make that happen. Any leads as to what color wires are under the dash near the column? That’s where all the wiring was done but I don’t even know where to start Link to comment Share on other sites More sharing options...
Tex06 Posted January 16, 2024 Share Posted January 16, 2024 13 hours ago, Aidenmoreno3 said: Aight so here we are again I've been doing research on the horn infamous horn problem however, my situation had a little bit of a twist When I bought the truck the previous owner had an alarm system hooked up to the factory horns and they worked, but the actual horn did not, only when the alarm went off. Eventually the alarm system stopped working altogether and with it went the horns. that alarm system turned out to be wired a little less than ideal and I was worried about a possible fire so I just payed someone to re do the whole thing. He installed one of those little chirp alarms that come with the kit and I was happy with the noise. problem is now I have no idea what wires were cut, or disconnected in order to make that happen. Any leads as to what color wires are under the dash near the column? That’s where all the wiring was done but I don’t even know where to start Do you just need a copy of the 92 wiring diagram? I have one, just have to figure out where it is.... Link to comment Share on other sites More sharing options...
gogmorgo Posted January 16, 2024 Share Posted January 16, 2024 Anything happen when you push the horn button? The horn button switches the ground side of a relay, effectively by shorting to the steering column. The horn relay is under the dash, it looks like any other relay but when you pull it out it only has three prongs on it. I can’t remember off the top of my head, I think it’s in a block of two, maybe three others. I think they’re supposed to be velcroed to the lower dash but mine were just loose. Of the three pins, one has constant power, one should have ground when you push the horn button, and the other should have some continuity to ground via the horn(s) and should make them sound if you put power to it. When I got my first MJ the horn didn’t work. The guy I bought it from said it needed a new relay. In reality there were actually pieces missing for the horn switch, specifically that parts that go through the steering wheel. When I was correcting that I discovered just how easy it is to damage those bits that go through the steering wheel. Link to comment Share on other sites More sharing options...
schardein Posted January 17, 2024 Share Posted January 17, 2024 Here is what a horn relay looks like, and how to test it without damaging it. Link to comment Share on other sites More sharing options...
pizzaman09 Posted January 17, 2024 Share Posted January 17, 2024 You are making me think, I wonder if I've ever tested the horn in mine, never considered using it. Link to comment Share on other sites More sharing options...
Aidenmoreno3 Posted January 19, 2024 Author Share Posted January 19, 2024 On 1/16/2024 at 9:43 AM, Tex06 said: Do you just need a copy of the 92 wiring diagram? I have one, just have to figure out where it is.... I do have it, I’m just not seeing the exact colors coming off of the same areas that the diagram is showing me Link to comment Share on other sites More sharing options...
gogmorgo Posted January 19, 2024 Share Posted January 19, 2024 Yeah you really can’t reliably use wire colours, too many year to year changes. You need to look for connector pin locations. Link to comment Share on other sites More sharing options...
