vfb Posted January 14, 2024 Share Posted January 14, 2024 I was plowing some really deep snow and when I looked under the truck afterwards (because of a blown lower rad hose-but that’s a different story! ) and saw this dangling right behind the front differential on the driver side. Being an old geezer and lying on the freezing snow, I couldn’t see anywhere obvious that it should go. Hopefully somebody can recognize it and point me in the right direction. Thanks of course! Link to comment Share on other sites More sharing options...
The86manche Posted January 14, 2024 Share Posted January 14, 2024 It looks like the antena cable Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 14, 2024 Share Posted January 14, 2024 What year truck? Is your oxygen sensor still there? Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 14, 2024 Share Posted January 14, 2024 1 hour ago, vfb said: I was plowing some really deep snow and when I looked under the truck afterwards (because of a blown lower rad hose-but that’s a different story! ) and saw this dangling right behind the front differential on the driver side. Being an old geezer and lying on the freezing snow, I couldn’t see anywhere obvious that it should go. Hopefully somebody can recognize it and point me in the right direction. Thanks of course! If it's on the drivers side and you drive on the left side, it's your O2 sensor! Here's one with the same style slots on the o2 sensor. Link to comment Share on other sites More sharing options...
vfb Posted January 14, 2024 Author Share Posted January 14, 2024 Thanks for those replies. It’s an 89 4.0 and yes, left hand driver. To be honest, I’m such a novice that I’m not sure whether the oxygen sensor is there or not. I’ll check though. The main question of course is whether this is an essential thing, or could I get through the winter plowing my driveway without it? Link to comment Share on other sites More sharing options...
pizzaman09 Posted January 15, 2024 Share Posted January 15, 2024 5 hours ago, vfb said: Thanks for those replies. It’s an 89 4.0 and yes, left hand driver. To be honest, I’m such a novice that I’m not sure whether the oxygen sensor is there or not. I’ll check though. The main question of course is whether this is an essential thing, or could I get through the winter plowing my driveway without it? It will run but it will run better and a lot more efficiently with a working oxygen sensor. Link to comment Share on other sites More sharing options...
vfb Posted January 15, 2024 Author Share Posted January 15, 2024 Thanks. That’s pretty much what I imagined. Took a look and I doubt if it’s ever been changed so probably will be a struggle to get out. Might just wait until the weather warms up a bit. Link to comment Share on other sites More sharing options...
Eagle Posted January 15, 2024 Share Posted January 15, 2024 It will continue to run but, without the O2 sensor, it will never switch into closed loop mode for fuel trim. As Pizzaman09 already commented, it will run better with an O2 sensor. If you only use it to plow your driveway you'll be okay, but if you actually use the truck to drive anywhere you'll get better performance and better fuel economy if you replace it. Link to comment Share on other sites More sharing options...
vfb Posted January 15, 2024 Author Share Posted January 15, 2024 Thanks for the guidance and advice guys. Given how busted the old one looks it’s probably been non functional for a while and yes for now just plowing myself and neighbours so I’ll wait to deal with it Link to comment Share on other sites More sharing options...
dreaminbohemian Posted January 15, 2024 Share Posted January 15, 2024 In a tangental question is there anything else in that harness line running down the left side of the engine that would prevent it from running? My speedo cable came loose and wrapped around my front drive shaft, the part of the harness that goes down the drivers side of the engine was severed. It would turn over but not start. I can see at least 4 wires in my poor photo but the vehicle is 90 mins away. If it will run without the O2 sensor what else was cut in that loom? Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 15, 2024 Share Posted January 15, 2024 I believe the knock sensor wiring is also in that loom but should not prevent it from running. Link to comment Share on other sites More sharing options...
