KANTANKRUS Posted June 24, 2023 Share Posted June 24, 2023 *** Asking for a friend, where can he get a Neutral Safety Switch for the above truck, with the stated equipment? Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 24, 2023 Share Posted June 24, 2023 I'm not aware of any Comanche having a neutral safety switch. There is a switch for disengaging cruise control on a manual Comanche. I assume you are referring to a clutch switch. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted June 24, 2023 Author Share Posted June 24, 2023 30 minutes ago, pizzaman09 said: I'm not aware of any Comanche having a neutral safety switch. There is a switch for disengaging cruise control on a manual Comanche. I assume you are referring to a clutch switch. Oh, I am just repeating what he called it. Were is this 'clutch switch' located? Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 24, 2023 Share Posted June 24, 2023 4 minutes ago, TurtleHare said: Oh, I am just repeating what he called it. Were is this 'clutch switch' located? Way up high near the pedal pivot. I'll repeat, this part is for disengaging cruise control. It's not a common part as there are not a lot of Renix Jeeps with a manual and cruise. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted June 24, 2023 Author Share Posted June 24, 2023 Yeah, that's not it! I just sent him a text... now I wait for his reply. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 24, 2023 Share Posted June 24, 2023 As an owner of a 87 MJ with an AX15, it doesn't have, never had, and doesn't need a NSS. Your friend has been given bad advise. Link to comment Share on other sites More sharing options...
acfortier Posted June 24, 2023 Share Posted June 24, 2023 Are you sure it's an AX-15? Would have had to be swapped in at some point in time. A simpler question would be if it's a manual or auto. If it's the auto, it should have a NSS. Link to comment Share on other sites More sharing options...
87MJTIM Posted June 24, 2023 Share Posted June 24, 2023 I don’t believe the Renix Jeeps had a NSS, but I’ve never had an automatic. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 24, 2023 Share Posted June 24, 2023 11 minutes ago, 87MJTIM said: Renix Jeeps had a NSS They do, theres some NOS and theyre expensive as hell. Chrysler in a bulletin said to clean them up and one of the techs at work who was working on Renix jeeps years ago said inside the NSS is actual gold contacts, hence the cost of them. Link to comment Share on other sites More sharing options...
Pete M Posted June 25, 2023 Share Posted June 25, 2023 the manual transmission MJs most definitely do not have any device that prevents you from turning the key while the shifter is in gear and thus letting the starter move the truck forward (and eventually starting said truck and driving away). very handy technique when your clutch fails on you. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 25, 2023 Share Posted June 25, 2023 Or if she doesn't run you can put it in 4low to get it on the trailer😁 Link to comment Share on other sites More sharing options...
KANTANKRUS Posted June 26, 2023 Author Share Posted June 26, 2023 My friend was in an area, with very poor cell signal, so he didn't respond until he got back to civilization late last night. Now he is at work... so his reply must now wait, yet again. Link to comment Share on other sites More sharing options...
KANTANKRUS Posted June 26, 2023 Author Share Posted June 26, 2023 He is a young buck, and he is chasing tail, so his truck is not a priority... lol! He will get back to me, at some point! I just sent him a text, asking him to not only reply but also to crawl under his MJ and snap some photos of just what we are actually dealing with. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 29, 2023 Share Posted June 29, 2023 On 6/25/2023 at 10:05 AM, TurboedMJ said: Or if she doesn't run you can put it in 4low to get it on the trailer😁 Been there and done that, 4L with a non functioning clutch and about 8 inches of dense snow. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 29, 2023 Share Posted June 29, 2023 35 minutes ago, pizzaman09 said: Been there and done that, 4L with a non functioning clutch and about 8 inches of dense snow. Man I was lucky, I had dry ground to do it on😄 Link to comment Share on other sites More sharing options...
