Eagle_SX4 Posted July 18, 2024 Author Share Posted July 18, 2024 Started sanding the drivers door and cab corner. Bad news is I found a bunch of bondo on the back of the cab. Something hit the cab corner hard. There is damage from about the vents down to the lower body line. However the lower rocker and bed are untouched. A view from inside. Whoever painted it last made a poor attempt to pull it out. I bought some body hammers and spent about 1.5 hours massaging the panel and it is already much smoother than before I still need to get the rest of the bondo off and see just how good I can make this before I paint it. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted July 20, 2024 Author Share Posted July 20, 2024 Drove to the junkyard today. I gassed up before and after just to see what my gas mileage was after the gear change (4.10's). Wow was I surprised when I learned that over my 100 mile journey averaging about 55-60 I got 23.25 mpg. The best I ever got on the same trip with the 3.07's was 19. Didn't get much but there was an interesting Cherokee there. It was an '88 that had '92 Briarwood doors, fenders, dash and center console. Also had 96+ motor swap and 96+ seats with the added floor braces for those seats. Also I found out that there are 3 different wood grain dash bezels. Wagoneer light wood with a matte finish with raised chrome lines around the openings. Briarwood, the same as Wagoneer but darker and no chrome. Country gloss finish with the same color as Briarwood but no raised lines. Now I have all 3. Not sure which one I will put in my truck but it will probably be the Briarwood. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted July 21, 2024 Author Share Posted July 21, 2024 Started to address the dents in the rear cab corner. Before After I need to remove the bed before I finish it up. Will be pb blasting the bolts every day so that by Friday when I take the bed off hopefully it will go smoothly. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted July 26, 2024 Author Share Posted July 26, 2024 Got the bed pulled today. There is only surface rust on the spot welds. Nothing else, just a bunch of dried mud. By some miracle I was able to get all 8 bolts/nuts off without breaking any. They will get replaced as they are quite rusty. Used my engine lift and 6 ratchet straps and pulled it off by myself. Now I have better access to the damage on the corner. So much bondo Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted July 31, 2024 Author Share Posted July 31, 2024 Well I got the cab corner fixed as best I could. Put a skim coat of bondo on. Found some rust holes in the passenger rocker panel. I ordered a new rocker from key parts and will get that swapped in before I paint. The doors and fenders are pulled off in preparation for painting the cab. I should be ready to paint the cab on Saturday. Then it will be the doors, hood and header panel. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 3, 2024 Author Share Posted August 3, 2024 Got the rocker cut out and the new one almost fully welded in. I will finish welding tomorrow and hopefully start painting. Link to comment Share on other sites More sharing options...
Jdde Posted August 14, 2024 Share Posted August 14, 2024 On 3/13/2024 at 8:15 PM, Eagle_SX4 said: Recently got Bilstein 5100 shocks on all 4 corners and they are so much better than old the old ones. Had some new cheap pro comps on the front but the Bilstein's blow them out of the water. Expand Do you know what part number you used for the rear? Stock height? Trying to piece together my suspension overhaul and haven't found a 5100 rear shock. Several posts mentioned the 5125 though for the rear. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 14, 2024 Author Share Posted August 14, 2024 On 8/14/2024 at 5:14 PM, Jdde said: Do you know what part number you used for the rear? Stock height? Trying to piece together my suspension overhaul and haven't found a 5100 rear shock. Several posts mentioned the 5125 though for the rear. Expand My bad I have 5125 front and rear. Rears are Bilstein 33-186542 EXTENDED 24.35 COLLAPSED 15.12. Fronts are Bilstein 24185622 extended 22.09 collapsed 13.58. The rear shocks are about 1 inch longer when compressed compared to the stock ones so you will need to adjust your bump stomps. Link to comment Share on other sites More sharing options...
Jdde Posted August 14, 2024 Share Posted August 14, 2024 On 8/14/2024 at 5:35 PM, Eagle_SX4 said: My bad I have 5125 front and rear. Rears are Bilstein 33-186542 EXTENDED 24.35 COLLAPSED 15.12. Fronts are Bilstein 24185622 extended 22.09 collapsed 13.58. The rear shocks are about 1 inch longer when compressed compared to the stock ones so you will need to adjust your bump stomps. Expand Great, thanks. I'm looking at the 33-185606 for the rear. They are 14.06 compressed, 22.5 extended. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 16, 2024 Author Share Posted August 16, 2024 Haven't done much in the last 2 weeks because I got covid. Today I got the rocker fully welded in and welded up the hole in the cowl. Also I installed a 97+ washer reservoir and got it wired and plumbed. Eventually I am going to add the low washer function but that will be later. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 7, 2024 Author Share Posted September 7, 2024 Finally making progress on the cab. Got it primed today. Will be doing color next weekend. Link to comment Share on other sites More sharing options...
NRT_Chris Posted September 7, 2024 Share Posted September 7, 2024 Very cool Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 21, 2024 Author Share Posted September 21, 2024 The wait is over the cab is painted!! Next will be the doors. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted September 21, 2024 Share Posted September 21, 2024 On 9/21/2024 at 3:15 AM, Eagle_SX4 said: The wait is over the cab is painted!! Next will be the doors. Expand Woah, nice job. How did you get the rear glass trim piece off without ruining it? These are great photos, it's nice to see how to properly mask the vehicle off for paint. dang. wow. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 21, 2024 Author Share Posted September 21, 2024 On 9/21/2024 at 3:40 AM, Salvagedcircuit said: How did you get the rear glass trim piece off without ruining it? Expand Used my fingers to peel it out of the groove. It was pretty easy the corners were a little harder. The trick will be putting it back in with out taking the window out. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 24, 2024 Author Share Posted September 24, 2024 I got the rear window trim reinstalled without removing the window. I used a bent o ring tool to help get the inner lip behind the window frame. Link to comment Share on other sites More sharing options...
Drahcir495 Posted September 28, 2024 Share Posted September 28, 2024 Great job on the paint! I don’t know if the factory paint went through into the door jams and behind the cab, but great attention to details. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 28, 2024 Author Share Posted September 28, 2024 On 9/28/2024 at 1:43 PM, Drahcir495 said: Great job on the paint! I don’t know if the factory paint went through into the door jams and behind the cab, but great attention to details. Expand Thanks. The factory did not extend the blue paint in to the door jams or behind the cab. Just about 2 inches so you could tell when the bed was on the doors were closed. It was easy enough to extend the paint and I think it makes it look more complete. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted September 29, 2024 Author Share Posted September 29, 2024 Front mud flaps installed. Link to comment Share on other sites More sharing options...
M.T.Hands Posted September 29, 2024 Share Posted September 29, 2024 On 9/29/2024 at 2:15 AM, Eagle_SX4 said: Front mud flaps installed. Expand Those look great Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 3, 2024 Author Share Posted October 3, 2024 Staring to look good with the new paint. I got the doors gutted today in preparation for paint, hopefully on Saturday. Link to comment Share on other sites More sharing options...
89 MJ Posted October 3, 2024 Share Posted October 3, 2024 Looking very good! That blue really pops in the sun Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 3, 2024 Author Share Posted October 3, 2024 On 10/3/2024 at 4:12 AM, 89 MJ said: Looking very good! That blue really pops in the sun Expand Thanks it is a lot more work than I anticipated but it is turning out well. I think I am going to run out of warm weather before I can get the bed painted might have to wait till spring. Link to comment Share on other sites More sharing options...
89 MJ Posted October 3, 2024 Share Posted October 3, 2024 I’m hoping the warmer weathers hangs in there for a while Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 13, 2024 Author Share Posted October 13, 2024 Well I got the doors painted today. But I won't be able to paint anything else this year. It will be to cold starting next week. I will assemble the doors tomorrow and get them back on the truck. I built a rotisserie for the doors that allowed me to paint them both at the same time. It worked really well. Link to comment Share on other sites More sharing options...
