Jdde
Jdde's Achievements
  1. Great, thanks. I'm looking at the 33-185606 for the rear. They are 14.06 compressed, 22.5 extended.
  2. Do you know what part number you used for the rear? Stock height? Trying to piece together my suspension overhaul and haven't found a 5100 rear shock. Several posts mentioned the 5125 though for the rear.
  3. Yes, the radiator had the provision for it, but my sensor did not fit. I believe the radiator was an m18 thread and the sensor m22. I was under the impression that sensor port was only used on the renix era vehicles, so not sure why the manufacturer would make this change. Everything I read online including the photos on the Amazon reviews showed that oem sensor fitting correctly. I assume they made a change or sent out a bad batch with the wrong threaded insert in the plastic. I ended up getting a different radiator from auto zone. Had the same 1193 part number and it fit just fine without issue.
  4. Working on switching to an open cooling system. Radiator needed to be replaced, so I purchased the Spectra CU1193 radiator. I was under the impression this would be a direct swap including my old auxiliary fan switch. My old switch is larger and does not fit in the radiator. What are my options? Is there a different fan switch that will fit in this location?
