9 hours ago, 89 MJ said:
How does it drive now that you’ve added it?
It does make a difference when cornering and seems more stable going down the road.
  • Replies 149
  • 4 weeks later...
Huge win at the junkyard this weekend. I picked up a clean non cracked dash and ac/heater box with controls. I will finally have ac in the car. I need to get a compressor and condenser and wire up the switches.213302735_IMG_20250621_1255228172.jpg.08b0a6e5b5c8435523f876cd01da795a.jpg1439945360_IMG_20250621_1256263023.jpg.2678101ac5e257a81dd36ac3ac591e29.jpgI will paint this dash black and get it installed with the new HVAC box hopefully later this summer.
1 hour ago, 89 MJ said:
Must not have been an Eagle dash, unless it was a 119 rig. Was it from a Concord or a Spirit?
I pulled it from a 1980 Eagle 4 door sedan. NP119 full time transfer case with no shifter switch on the dash. Not a big deal I just need to cut a square hole for the switch.
Gotcha. I figured it either had to be something like that or from a 2wd car.
  • 7 months later...
Over the last 2 weeks I have put brand new springs on it front and back. The new front coils I got from ESPO Springs and Things and the rear leafs I got from General Spring.
The new front coils did not drop the front like I was hoping(has about 2 inch lift). However the rear leafs did drop it factory height in the rear.
To lift the rear up, I pulled the old leaf pack apart and cut the eyes off the main spring and added it to the new pack and now the rear is at 2 inch lift. It should ride a lot better than the 3 inch lift I had with the XJ add-a-leaf.
I also was hoping the new leafs would fix the rear wheel center in the wheel arch I was fighting. They did not. So I moved the rear axle forward about 1/2 inch. Now the rear wheels are centered in the wheel well and should never rub the mud flaps again. I did this by drilling new holes in the leaf spring perch on the axle and in the spring plates. It came out really well and am very happy with the results.
  • 4 months later...
A/C is actually happening. I found a kit from Jeepair (8011) that flips the ac compressor and alternator for the 4.2 v-belt setup I am running on my 4.0.IMG_20260626_1622080392.jpg.1cce834ac1ccbe1b5e91bbd7daf1bed5.jpg
Now I still need to install the HVAC box, condenser, make custom hoses and wire it up.
This morning I swapped an aluminum 4.2 valve cover on to my 4.0. The only mod I did was the Cruiser54 valve cover mod. Right now I have the PCV valve in the back spot but will probably mod a front vent connector to have a metered orifice like the 4.0 valve covers have.IMG_20260627_094236166_HDR2.jpg.ce8ae3392ca5793b0119e1b686a5fdc1.jpg
Since I put a fresh 4.0 into my Comanche. I have noticed just how much clatter the tired 4.0 in my Eagle has. So I have decided to build a 4.6 stroker for it. Last week I picked up a 4.2 crankshaft. Today I picked up the block and head I am going to use. '96 NVH block with a 7120 head (soon to be ported). I need to decide on what pistons and cam I am going to run then it will be off to a machine shop.IMG_20260710_1625569022.jpg.e6d919c360a427a3ed29fc9c52e5c5fb.jpg
The short block came out of a '97 TJ (P.O. rebuilt a different motor and swapped it out) and the head I got out of a '93 ZJ in the junkyard.
18 minutes ago, 89 MJ said:
This is going to be great!
I am very excited. This build is slowly becoming an Eagle AMX. If only I could find a brushed aluminum dash for it.
Now that would be very neat! You could get brushed aluminum tape for the dash.
On with the AMX theme.IMG_20260713_185057537_HDR2.jpg.0c5c9e5b3ae88f1befeb151cd8b54222.jpg
The spoke slots in the horn button had to be widened to fit the earlier wheel. Otherwise a direct swap for the bent steering wheel I had.
Is the D35 going to live behind that stroker?
I like the steering wheel in there.
Ultimately I would like to put a XJ44 under it but that will wait until I find one at a good price. If the 35 breaks I will might swap to a Chrysler 8.25 as they are easier to get quickly.
