Eagle_SX4 Posted April 9, 2025 Author Posted April 9, 2025 9 hours ago, 89 MJ said: How does it drive now that you’ve added it? It does make a difference when cornering and seems more stable going down the road.
Eagle_SX4 Posted May 7, 2025 Author Posted May 7, 2025 Got a set of factory mud flaps put on the back.
Eagle_SX4 Posted June 21, 2025 Author Posted June 21, 2025 Huge win at the junkyard this weekend. I picked up a clean non cracked dash and ac/heater box with controls. I will finally have ac in the car. I need to get a compressor and condenser and wire up the switches.I will paint this dash black and get it installed with the new HVAC box hopefully later this summer.
89 MJ Posted June 21, 2025 Posted June 21, 2025 Must not have been an Eagle dash, unless it was a 119 rig. Was it from a Concord or a Spirit?
Eagle_SX4 Posted June 21, 2025 Author Posted June 21, 2025 1 hour ago, 89 MJ said: Must not have been an Eagle dash, unless it was a 119 rig. Was it from a Concord or a Spirit? I pulled it from a 1980 Eagle 4 door sedan. NP119 full time transfer case with no shifter switch on the dash. Not a big deal I just need to cut a square hole for the switch.
Eagle_SX4 Posted June 21, 2025 Author Posted June 21, 2025 Only 5 whole digits on the odometer and AUTOMATIC 4W.D.
89 MJ Posted June 21, 2025 Posted June 21, 2025 18 minutes ago, Eagle_SX4 said: I pulled it from a 1980 Eagle 4 door sedan. NP119 full time transfer case with no shifter switch on the dash. Not a big deal I just need to cut a square hole for the switch. Gotcha. I figured it either had to be something like that or from a 2wd car.
Eagle_SX4 Posted June 27, 2025 Author Posted June 27, 2025 Finally got the hub caps stickers made. I might paint them as the painted section is faded but they came out really good.
Eagle_SX4 Posted February 15 Author Posted February 15 Over the last 2 weeks I have put brand new springs on it front and back. The new front coils I got from ESPO Springs and Things and the rear leafs I got from General Spring. The new front coils did not drop the front like I was hoping(has about 2 inch lift). However the rear leafs did drop it factory height in the rear. To lift the rear up, I pulled the old leaf pack apart and cut the eyes off the main spring and added it to the new pack and now the rear is at 2 inch lift. It should ride a lot better than the 3 inch lift I had with the XJ add-a-leaf. I also was hoping the new leafs would fix the rear wheel center in the wheel arch I was fighting. They did not. So I moved the rear axle forward about 1/2 inch. Now the rear wheels are centered in the wheel well and should never rub the mud flaps again. I did this by drilling new holes in the leaf spring perch on the axle and in the spring plates. It came out really well and am very happy with the results.
Eagle_SX4 Posted Friday at 10:26 PM Author Posted Friday at 10:26 PM A/C is actually happening. I found a kit from Jeepair (8011) that flips the ac compressor and alternator for the 4.2 v-belt setup I am running on my 4.0. Now I still need to install the HVAC box, condenser, make custom hoses and wire it up.
Eagle_SX4 Posted yesterday at 03:52 PM Author Posted yesterday at 03:52 PM This morning I swapped an aluminum 4.2 valve cover on to my 4.0. The only mod I did was the Cruiser54 valve cover mod. Right now I have the PCV valve in the back spot but will probably mod a front vent connector to have a metered orifice like the 4.0 valve covers have.
