Whitaker717 Posted February 9, 2023 Share Posted February 9, 2023 Looking to replace my front shocks on my 87. I am looking for stock height. I am not lifted and don’t plan on it. I have the Rancho RS 5000x on the rear. I’m not sure if I should get the same brand or different for front. Thanks guys Link to comment Share on other sites More sharing options...
PIKE Posted February 9, 2023 Share Posted February 9, 2023 Ok, I will start. I like the Bilstein 5125 https://offroad.bilstein.com/en-us/products/bilstein-b8-5125/ Link to comment Share on other sites More sharing options...
Airborne Janitor Posted February 9, 2023 Share Posted February 9, 2023 43 minutes ago, PIKE said: Ok, I will start. I like the Bilstein 5125 https://offroad.bilstein.com/en-us/products/bilstein-b8-5125/ 2ndedededed. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 9, 2023 Share Posted February 9, 2023 The 5000X is a great chock for the price. Do you do any high speeds on rough roads, gravel, washboards etc? Stock axles? What size tires? Any added weight to your MJ? Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 9, 2023 Share Posted February 9, 2023 I put Rancho RS 5000X on the front of mine a few weeks ago. Completely stock suspension setup and truck in general. I am pleased with them. Definitely good for the price. I have much cheaper new KYB shocks on the rear, they too are a wonderful upgrade over the old blown ones. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 9, 2023 Author Share Posted February 9, 2023 4 hours ago, ghetdjc320 said: The 5000X is a great chock for the price. Do you do any high speeds on rough roads, gravel, washboards etc? Stock axles? What size tires? Any added weight to your MJ? Not typically too rough. I have 30 min commute on interstate to work. Stick axles. A bit bigger than stick wheels but still 15” turbines. No added weight. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 9, 2023 Author Share Posted February 9, 2023 3 hours ago, pizzaman09 said: I put Rancho RS 5000X on the front of mine a few weeks ago. Completely stock suspension setup and truck in general. I am pleased with them. Definitely good for the price. I have much cheaper new KYB shocks on the rear, they too are a wonderful upgrade over the old blown ones. What is the model number of your front shocks? I’m guessing you have the tabs or fins on yours as well? Link to comment Share on other sites More sharing options...
AZJeff Posted February 9, 2023 Share Posted February 9, 2023 I don't like Rancho suspension parts in general, so I an going to suggest an alternative for the front: KYB They are modestly priced, and provide good balance between dampening and ride. Another good choice is Quadratec's house brand of shocks. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 9, 2023 Share Posted February 9, 2023 1 hour ago, AZJeff said: I don't like Rancho suspension parts in general, so I an going to suggest an alternative for the front: KYB They are modestly priced, and provide good balance between dampening and ride. Another good choice is Quadratec's house brand of shocks. Have you tried the 5000x series? Rancho had a pretty bad rep until they made these shocks. They are truly a great shock for the price. Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 9, 2023 Share Posted February 9, 2023 1 hour ago, Whitaker717 said: What is the model number of your front shocks? I’m guessing you have the tabs or fins on yours as well? I purchased RS55128. I am not quite sure what you mean by tabs or fins. The Rancho shock came with 100% of the new hardware required including bolts. 1 hour ago, AZJeff said: I don't like Rancho suspension parts in general, so I an going to suggest an alternative for the front: KYB They are modestly priced, and provide good balance between dampening and ride. Another good choice is Quadratec's house brand of shocks. I like the softer ride if the KYB in the back, I would have purchased them for the front but I couldn't find a source of them. That said my Ranchos in the front ride fine. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 10, 2023 Author Share Posted February 10, 2023 1 hour ago, pizzaman09 said: I purchased RS55128. I am not quite sure what you mean by tabs or fins. The Rancho shock came with 100% of the new hardware required including bolts. I like the softer ride if the KYB in the back, I would have purchased them for the front but I couldn't find a source of them. That said my Ranchos in the front ride fine. So my front shock looks like this. With these tabs on the bottom Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 10, 2023 Author Share Posted February 10, 2023 Link to comment Share on other sites More sharing options...
pizzaman09 Posted February 10, 2023 Share Posted February 10, 2023 6 minutes ago, Whitaker717 said: So my front shock looks like this. With these tabs on the bottom Yep, those tabs come with the shock. Install that end first, then rotate it up to align the rod with the hole in the wheel well. Here it is installed in mine, the white tab will be pre installed into the bushing. Link to comment Share on other sites More sharing options...
Whitaker717 Posted February 10, 2023 Author Share Posted February 10, 2023 2 minutes ago, pizzaman09 said: Yep, those tabs come with the shock. Install that end first, then rotate it up to align the rod with the hole in the wheel well. Thanks a lot. Those are what I was leaning towards but just to match. Link to comment Share on other sites More sharing options...
AZJeff Posted February 10, 2023 Share Posted February 10, 2023 To answer multiple comments on this thread: I have not tried the "5000" series Rancho shock, so I cannot comment on that particular version. I am just not a big fan of Rancho suspension parts in general, as I think there are better aftermarket brands than theirs, and at similar prices. The "Tab" various people are referring to on the lower end of the front shock absorber in an XJ/MJ is called a "bar pin" Link to comment Share on other sites More sharing options...
