ghetdjc320 Posted November 5, 2022 Posted November 5, 2022 Looking for a connector that plugs in to the back of the power mirror switch. Looks like some kind of molex connector. Here is a picture of where it plugs in. Also, any sort of wiring diagram would be most excellent as I will be building the harness for the mirrors. Tagging @Minuit @eaglescout526
eaglescout526 Posted November 5, 2022 Posted November 5, 2022 It looks molex but I wouldn’t say that’s for certain. There is no inscription on the plug anywhere.
howeitsdone Posted November 5, 2022 Posted November 5, 2022 Closest I've found https://www.kinkong-connector.com/products/7118-3070mg6202124g0700-0007pinmaleautoconnectionckk5071n-30-11-ID7905.html
ghetdjc320 Posted November 5, 2022 Author Posted November 5, 2022 40 minutes ago, howeitsdone said: Closest I've found https://www.kinkong-connector.com/products/7118-3070mg6202124g0700-0007pinmaleautoconnectionckk5071n-30-11-ID7905.html Looks right. Just need the other side of it
ghetdjc320 Posted November 5, 2022 Author Posted November 5, 2022 56 minutes ago, eaglescout526 said: It looks molex but I wouldn’t say that’s for certain. There is no inscription on the plug anywhere. Any chance you could spare that part of the harness?
ghetdjc320 Posted November 5, 2022 Author Posted November 5, 2022 22 minutes ago, Big_Mark said: Maybe it's time to visit a junk yard? I seem to be in an area void of an power mirror cherokees
eaglescout526 Posted November 5, 2022 Posted November 5, 2022 Let me do some digging of the harnesses I have. I might have another one from all the dash harnesses I got from another member. Right now that’s my only one.
ghetdjc320 Posted November 5, 2022 Author Posted November 5, 2022 18 minutes ago, eaglescout526 said: Let me do some digging of the harnesses I have. I might have another one from all the dash harnesses I got from another member. Right now that’s my only one. No worries. Although I could use all the mirror wiring, I really just need the connector or pigtail and can build my own.
howeitsdone Posted November 5, 2022 Posted November 5, 2022 This is the female side part number MG610203 You'd need the terminals though. https://nexelec.com/KET-MG610203/
howeitsdone Posted November 5, 2022 Posted November 5, 2022 Actually looks like the Aliexpress product comes with 7 terminals. Just takes a few weeks. Maybe less to Guam if you're there currently. https://www.aliexpress.com/i/2251832574069212.html?gatewayAdapt=4itemAdapt
Minuit Posted November 5, 2022 Posted November 5, 2022 AMP MIC Mark-II. Also used in radios. The pins crimp very well with a standard ratchet crimper. https://www.corsa-technic.com/item.php?item_id=1142
eaglescout526 Posted November 5, 2022 Posted November 5, 2022 1 hour ago, ghetdjc320 said: No worries. Although I could use all the mirror wiring, I really just need the connector or pigtail and can build my own. I don’t have all the mirror wiring. Took me a bit to even find a drivers side I could use for my XJ. But I still might have something from the dash side.
ghetdjc320 Posted November 6, 2022 Author Posted November 6, 2022 3 hours ago, Minuit said: AMP MIC Mark-II. Also used in radios. The pins crimp very well with a standard ratchet crimper. https://www.corsa-technic.com/item.php?item_id=1142 That’s it! Wonder if the mirrors themselves are also amp connectors.
Minuit Posted November 6, 2022 Posted November 6, 2022 7 minutes ago, ghetdjc320 said: That’s it! Wonder if the mirrors themselves are also amp connectors. The ones on mine are Metri-Pack 150, unsealed 3-pin. But I think they used Molex at one point.
eaglescout526 Posted November 6, 2022 Posted November 6, 2022 What Minuit said. I recently took a power mirror harness and pushed it through a non-power mirror door harness by de-pinning the 3 pin metri-pack.
