What to do
   Good evening folks about 7-8
years ago and came across this 89 Jeep comanche that a feller sold me for 800$ needed a transmission everything was their hadn't been dogged some rust on the floor pans but all is well now it had like almost 400,000 and now around 456,000 hard on off road give or take a 1000 miles it being what I believe to be original motor. All that being said
  The 89 Jeep comanch straight six 4.0
Being the Renix or Renault/Benix AMC was Cast Iron Block and Heads??  Mine is doing a light knocking due to all the miles sounds like by the oil plug so a bearing or something I'ma drive it till it blows but I was looking at this place online called jegs that has a remanufactured one for right at two grand block and head and it says cast iron and y'all recken that be just as good as haven mine rebuilt.. I'd get mine rebuilt but the  remanufactured afford like a 7 year warranty which is better then if I  had mine rebuilt and in 3 years something happend no warranty vs up to 7 yrs what's y'all opinion or point me in the right direction please thanks much
456,000 miles. I have not checked the compression. It still runs like it did just with a light knock. Ive not thought about that. I assume by dropping it be obvious to see if it is a bearing? And can you just by them at your local napa O'Riley advanced auto parts place or need to be ordered? Thanks for the response and input
You'll probably have to order the bearings, stores don't carry much for older vehicles anymore.  At least from my experience.  Checking the compression is a great start and I'd even consider pulling the pan just to get eyes on underneath.  If it was top end noise I wouldn't worry as much but bottom end is a little more serious.
You could always take the route of thicker oil to make the knock go away and keep driving.  Doesn't actually fix anything but out of... sound, out of mind?
have you ever inspected crank bearings before?  if not, I'd suggest a youtube vid to get a peek into what's required. :L:
Ok so I was reading other things on the club and started with the cheapest first turns out it was the Flex Plat THANK GOD however I still wanna change the oil pump it's never been changed at least sense I've had it.. the oil gauge reads about or between 40 and 80 like  so just over the half line it doesn't burn or leak oil...should I change it or leave it be?
Also I've got several wires under the hood and under dash I'm not sure what they are I seen someone post some pictures but I couldn't tell exactly what wires they are
If it makes good oil pressure (I believe 20lbs at hot idle is considered sufficient), I would leave it. No sense in spending unnecessary money, and the newer aftermarket parts tend to fail quicker than OEM do.
Actually, 13 psi at hot idle is the minimum factory spec.
9 minutes ago, AbreedApart89South said:
 my oil pressure gauge reads 0 - 40 - 80 but the hand stays a little over 40 when running
40 at idle, or 40 at highway speed? It should be higher at highway speed. 40 at idle would be good for a NEW engine.
I will elaborate on what Eagle said about oil pressures.
The 4.0 engine has "official factory approved" oil pressures of 13psi minimum at idle, and above 1600 rpm, it should be between 37 and 75psi.   These numbers are, of course, with factory recommended 10w30 oil and with a hot (fully warmed up) engine.
I think the reason the pressure range is so wide when measured at 1600+ rpm is because, in my experience, there is a pretty broad range of oil pressures reported by various owners with the 4.0    For example, on my MJ, the hot idle oil pressure is about 23psi, which is well above factory minimums.   However, that same engine, when it gets fully hot (and I mean REAL hot here in Phoenix) only puts out about 42psi at 1600 rpm, which is at the low end of recommended.
Another factor to consider, and this is just my personal opinion, and not backed up by any data, is that the 4.0 isn't an engine that is extremely demanding of  high oil pressures to function as expected.   in other words, as long as your engine is making steady oil pressure, the engine is fine with a pretty broad range of oil pressure values.
Well I appreciate the information y'all I reckon my Jeep is doing all it should running gear wise. Thanks again
