87 Chief
Just picked up this 87 Chief that I've been waiting to get for a long time. I'm actually trading labor for it, I pull the axles, trans, transfercase, and engine(I keep the a/c parts though), and I get to keep the rest of the truck. The main thing is just the interior and A/C I was after, but theres still a few more things around the truck I can still use. I made this thread because I already have a few questions and am sure I will have more later.
First question is does anybody know what the switch on the right in the last pic does, the light comes on for it. Also, its supposed to run and drive, and it starts on aether but doesn't get fuel, can't hear the fuel pump turn on. The ground wire for it has already been cleaned behind the light and I did it again with no luck. Idk if this gives any useful information but I noticed the fuel gauge goes wayyy passed fuel, the pic w the gauge cluster is with the key on.
  • Replies 86
I figured if the sport bar had lights then it would be on the same switch as the fog lights. And yes lol, the whole frame is about to give but somehow it still runs and drives. The front driverside leaf spring bracket is literally not connected to  the frame.
2 minutes ago, Pete M said:
lots of great parts there. :L: the frame is... not on that list.  lol.
Yeah, I'm gonna use 100% of the interior but obviously will have some leftover things such as parking brake and dome lights if anyone is interested in stuff, but I'll be coming back to here with more questions like if that rear bumper is in some way desirable or whatever.
*X8 SEATS - CLOTH LOW-BACK BUCKET
-Y1
3LX
ADA LIGHT PACKAGE
ADL SKID PLATE GROUP
AGI
APA MONOTONE PAINT PACKAGE
AWE
AWH POWER EQUIPMENT GROUP
AWJ Visibility Group
BCQ Battery - Maintenance Free
CAC BUCKET SEAT - LO BK
CGW
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CLE ACCESSORY FLOOR MAT - FRONT
CUF FULL LENGTH FRONT CONSOLE
DGQ TRANSMISSION-4SPD AUTOMATIC
DMR 3.55 Axle Ratio
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GFD SLIDING RR WINDOW
GTZ MIRRORS - MANUAL REMOTE
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JFH TACHOMETER - MECH
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
LBB COURTESY LAMPS (BELOW PANEL)
LDA UNDERHOOD COMPT LAMP
LMA HALOGEN HEADLAMPS
LNJ Fog Lamps
LPE EXTERIOR CARGO LIGHT
MBJ Bumper - Front, Black
MCA FRONT BUMPER GUARDS
MCB
MD8 Delete Front License Plate Bracket
MWB SPORT BAR
MWF BOX SIDE RAILS
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NHB HVY DTY/AUX TRANS OIL COOLER
NHM AUTO SPEED CONTROL
NMB ENGINE COOLING - STANDARD DUTY
PE4 Colorado Red
QE4 Colorado Red
RAF Radio - AM/FM Cassette
SBA POWER STEERING
SCG LEATHER STRG WHEEL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBB CONVENTIONAL SPARE TIRE
TBL TIRE CARRIER - INSIDE
WJN 15" Aluminum Wheels
XEA TOW HOOKS
Also, I need to figure out why the fuel pump doesn't turn on. I know about the bad ground behind the tail light, and someone already had cleaned it, but I cleaned it again and it didn't fix it. here's some pics of the mess of wires back there, if anything jumps out as an issue for the fuel pump please lmk. Also if there are any other common issues for a fuel pump not working please let me know.
A search of the registry does not bring up that vin so I started a new one.
best tear it all apart and inspect the wires individually.  also that connector has to be connected for the ground to work for the pump
Nevermind, I found the connector you were talking about, it slipped off at somepoint somehow, probably on the trailer over here, and it now runs and drives. Also it came with a whole spare tail light wiring harness from that plug back. Are they Comanche unique or basically the same as the Cherokee?
