ghetdjc320 Posted July 14, 2022 Share Posted July 14, 2022 Was wondering if anyone knows the specific types of plastic used for various interior panels. I will be doing some plastic welding and repairs to bring my interior back to perfect but will need to know the types used. Here are the components I’m looking to ID: Center console shell center console black insert b pillar trim a pillar trim dash bezel Tagging @Dzimm and @m2bandit as they both work heavily on interior plastic pieces. Link to comment Share on other sites More sharing options...
jdog Posted July 14, 2022 Share Posted July 14, 2022 It should be labeled somewhere on the plastic with a code, if I get a chance later I'll take a look at the console and see if I can find the code Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 14, 2022 Share Posted July 14, 2022 Aren’t they all ABS pieces? I know some parts will say what plastic it is and part number and production dates and what not. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 14, 2022 Author Share Posted July 14, 2022 I see production dates but I can’t identify a code. I believe there are some different types of plastic used for interior trim but it may be mostly abs. The center console and pillar trim tends to be a bit more brittle and crack. The kick panels and inner door sill trim on the other hand feel almost like a nylon material. Link to comment Share on other sites More sharing options...
AZJeff Posted July 14, 2022 Share Posted July 14, 2022 Putting recycling codes on polymer parts wasn't a common practice when the MJ's were in production, so it's not too surprising to see forum members reporting not finding such identifiers on interior parts. Based on my years of experience with resins when I earned a living as a mechanical engineer, I think that most of the pieces of the interior of an MJ are ABS. (Newer vehicles use ABS/polycarbonate blends for these applications, but the MJ predates that use.) ABS can be repaired by solvent welding and also with some of the filler resins out there pretty sucessfully. The kick panels and similar stuff are probably polypropylene, which is more flexible and has an almost "waxy" feel to it. Polyprop is much trickier to get welding to work successfully. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 14, 2022 Share Posted July 14, 2022 I swear I remember seeing a few things say “ABS” like the clock delete panel. But like AZ Jeff said, there aren’t and won’t be those plastic codes. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 14, 2022 Author Share Posted July 14, 2022 Good to know! Looks like all my repairs are with abs. The center console is always a trick to repair. Planning to use a Polyvance welder to do these repairs but needed to identify the right material. Thanks again! Link to comment Share on other sites More sharing options...
Dzimm Posted July 15, 2022 Share Posted July 15, 2022 7 hours ago, ghetdjc320 said: Was wondering if anyone knows the specific types of plastic used for various interior panels. I will be doing some plastic welding and repairs to bring my interior back to perfect but will need to know the types used. Here are the components I’m looking to ID: Center console shell center console black insert b pillar trim a pillar trim dash bezel Tagging @Dzimm and @m2bandit as they both work heavily on interior plastic pieces. I'd bet money they are ABS. Some form of ABS is used for more than 90% of interior plastics in vehicles, especially older ones. Newer vehicles are starting to utilize other types of plastic more, even 3D printing parts from the factory. I saw Nylon mentioned, Nylon is sometimes used but it's a much heavier duty material and used more on wear type items and structural items that need to be stronger, none of the mentioned pieces fall into that category. It's also more difficult and expensive to process than other suitable materials. I ran the injection molding department at Kreg Tool for several years (until they shipped manufacturing to China) and have a few injection molding certs and I can tell you from my experience that in most cases, ABS is the default for injection molded parts unless there is something that requires a certain property that can't be attained with ABS. Link to comment Share on other sites More sharing options...
m2bandit Posted July 15, 2022 Share Posted July 15, 2022 Most likely ABS, You could try acetone welding too. My internet isn't working well right now or I'd find a guide for you. Link to comment Share on other sites More sharing options...
OldSch88L Posted July 17, 2022 Share Posted July 17, 2022 A big part of plastic components I encountered during my body shop days was PP (polypropylene), but I can't say for sure for vehicles as old as MJs. However, you shoud be able to find "Universal" plastic welding rods; they're usually black with fiber in them. My boss didn't even bother identifying the kinds of plastics to use the right rods, he just used the universal ones all the time. The universal will work when you're not sure what you have, but you'll always get a better bond with the same kind of plastic. Link to comment Share on other sites More sharing options...
