87MJTIM Posted June 25, 2022 Posted June 25, 2022 We had a heavy rain the other day. A puddle of water accumulated on the driver's side floor (I pulled the carpet out a while ago until I can find the source of the leak). Feeling around on the floor for a water path and looking for drops hanging down from anything, I found drips on the fuse box. Is there a gasket or sealer I can put in between the two halves to stop the leaking?
Warren99 Posted June 25, 2022 Posted June 25, 2022 I have the same issue, but I ain't gonna make a guess so I'll be watching for an answer too
zomeizter Posted June 26, 2022 Posted June 26, 2022 I took apart the fuse box and main connector on my MJ a while back and used some high end clear silicone around the perimeter of the assembly, this took care of ONE leak source. At least on my beast, any and all perforations on the engine compartment side of the cab cause water intrusion. These will be addressed once the V6 dies and a real engine swap is performed.
87MJTIM Posted September 14, 2022 Author Posted September 14, 2022 I have been busy with work the past few months. I have not had time to do anything with the MJ (or anything around the house). I did replace a faucet in the bath not too long ago. While forming plumber's putty on the fixture, I thought "why not try this around the fuse box?" I could form a bead around the engine bay side of the box. It is not water soluble, doesn't stain, and remains soft over a long time. Am I missing something?
Eagle Posted September 14, 2022 Posted September 14, 2022 3 hours ago, 87MJTIM said: I have been busy with work the past few months. I have not had time to do anything with the MJ (or anything around the house). I did replace a faucet in the bath not too long ago. While forming plumber's putty on the fixture, I thought "why not try this around the fuse box?" I could form a bead around the engine bay side of the box. It is not water soluble, doesn't stain, and remains soft over a long time. Am I missing something? Sounds like a plan to me.
ghetdjc320 Posted September 14, 2022 Posted September 14, 2022 Have you tried to determine why the water is getting to the bulkhead connector in the first place? Is the hood to cowl seal good? Is the seam sealer on the sides still good? Is the cowl leaking down the firewall?
87MJTIM Posted September 14, 2022 Author Posted September 14, 2022 1 minute ago, ghetdjc320 said: Have you tried to determine why the water is getting to the bulkhead connector in the first place? Is the hood to cowl seal good? Is the seam sealer on the sides still good? Is the cowl leaking down the firewall? Not yet. Like I indicated, I have been busy the last couple months.
ghetdjc320 Posted September 14, 2022 Posted September 14, 2022 3 minutes ago, 87MJTIM said: Not yet. Like I indicated, I have been busy the last couple months. If water is getting down to the bulkhead area, it’s only a matter of time before it makes its way in through another seam or hole into the cab if it can’t get through the bulkhead connector. Water just shouldn’t generally be there. I know there are times when a few drops can get in there which is why I add a small drain hole from that area to the wheel well.
87MJJeep Posted September 19, 2022 Posted September 19, 2022 On 9/14/2022 at 12:31 PM, 87MJTIM said: I have been busy with work the past few months. I have not had time to do anything with the MJ (or anything around the house). I did replace a faucet in the bath not too long ago. While forming plumber's putty on the fixture, I thought "why not try this around the fuse box?" I could form a bead around the engine bay side of the box. It is not water soluble, doesn't stain, and remains soft over a long time. Am I missing something? I don't think the plumber's putty will remain soft indefinitely when subjected to high underhood temperatures. I'd use silicone caulking or something else similar.
ghetdjc320 Posted September 20, 2022 Posted September 20, 2022 7 hours ago, 87MJJeep said: I don't think the plumber's putty will remain soft indefinitely when subjected to high underhood temperatures. I'd use silicone caulking or something else similar. Agreed. Use automotive seam sealer
JIMMYRIG Posted November 24, 2025 Posted November 24, 2025 For those who have used sealers in caulk gun form, where are you applying sealer? I sealed from the cab side with urethane, then installed the fuse box and applied more on the engine side before bolting in the bulk head and it still leaks
JIMMYRIG Posted November 24, 2025 Posted November 24, 2025 Yeah I saw this, I already spent 50 dollars on a tube of urethane and want to make use of it before spending more money on a gasket. It also appears there are holes in the connector that would not be sealed by a gasket
