Pete M Posted June 24, 2022 Share Posted June 24, 2022 seems straight forward enough. it's an 88 4.0 Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 24, 2022 Share Posted June 24, 2022 If one stays in the fuel rail, a straight pick will get it out real easily. Make sure you have 6 o-rings accounted for before installing new ones. Otherwise, it's an easy job, I did my injectors one at a time when I upgraded to 4 holes. Just popped the rail back and did them on top of the manifold, expect to cover everything in fuel. Give it a minute to evaporate before restarting, check for leaks prior to and just after starting. Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 24, 2022 Share Posted June 24, 2022 Lube them with some motor oil. Link to comment Share on other sites More sharing options...
75sv1 Posted June 24, 2022 Share Posted June 24, 2022 I use Vaseline on the o rings. You should have 12 to start. If you have ones that are brown, those go to the manifold. I'd install them on the rail first. Then push them all as a unit. I think I had some issues the injectors in the manifold, to get the tops aligned in the fuel rail. Link to comment Share on other sites More sharing options...
75sv1 Posted June 24, 2022 Share Posted June 24, 2022 They also have a specific lube for o rings at the hardware store. I'd think trans fluid would be OK or even Power steering fluid. Link to comment Share on other sites More sharing options...
scguy Posted June 24, 2022 Share Posted June 24, 2022 We always use Vaseline at the shop. Works great. Link to comment Share on other sites More sharing options...
Pete M Posted June 24, 2022 Author Share Posted June 24, 2022 welp, the work is done. but I wasn't able to verify it's fixed due to some other issues. Link to comment Share on other sites More sharing options...
