89 MJ Posted June 20, 2022 Posted June 20, 2022 I need ideas for locations to mount a fire extinguisher in my truck for the AMC Homecoming show in July. I have a bench seat and would like it to be accessible from the driver seat. Also, if anyone has suggestions for the location for one in my Eagle, I’m game to hear those too.
Pete M Posted June 20, 2022 Posted June 20, 2022 waaaay back in the day I put mine on the pass side of the trans tunnel. I rarely had a passenger so it didn't matter (and if I did I could simply remove it and chuck it behind the seat). later I mounted it to the back wall right in the corner behind the driver (mounted to that 3/4" plywood wall I built). then I moved it outside in the bed so anyone could grab them if needed. The Liberty's is mounted to the pass side of the trans tunnel.
eaglescout526 Posted June 20, 2022 Posted June 20, 2022 What would be cool is if AMC had the foresight to make an indentation in one of the B-pillars for an extinguisher. Since there’s plenty of room for probably a small one to be clipped in. There’s probably plenty of space between the pass seat and lower B-pillar molding to put something there.
89 MJ Posted June 20, 2022 Author Posted June 20, 2022 1 hour ago, Pete M said: waaaay back in the day I put mine on the pass side of the trans tunnel. I rarely had a passenger so it didn't matter (and if I did I could simply remove it and chuck it behind the seat). later I mounted it to the back wall right in the corner behind the driver (mounted to that 3/4" plywood wall I built). then I moved it outside in the bed so anyone could grab them if needed. The Liberty's is mounted to the pass side of the trans tunnel. The side of the trans tunnel does sound like a pretty good spot. 50 minutes ago, eaglescout526 said: What would be cool is if AMC had the foresight to make an indentation in one of the B-pillars for an extinguisher. Since there’s plenty of room for probably a small one to be clipped in. There’s probably plenty of space between the pass seat and lower B-pillar molding to put something there. That sounds like a fantastic spot!
fiatslug87 Posted June 20, 2022 Posted June 20, 2022 I keep mine next to the passenger seat, it might fit on the driver's side but have not tried it. Edit: Just checked, it will fit on driver’s side (bucket seats).
fiatslug87 Posted June 20, 2022 Posted June 20, 2022 You have a sport bar on the MJ right? Mount it there for the show.
Gjeep Posted June 20, 2022 Posted June 20, 2022 One under each seat in all Jeeps. These actually have more juice than standard extinguishers. https://www.griotsgarage.com/ultra-compact-fire-extinguisher/?sku=26679&code=PPCPLG&gclid=EAIaIQobChMIpvn4wpS9-AIVICCtBh11GQxjEAQYASABEgI8NPD_BwE
89 MJ Posted June 20, 2022 Author Posted June 20, 2022 20 minutes ago, fiatslug87 said: You have a sport bar on the MJ right? Mount it there for the show. I do have a sport bar, that might be a good spot too.
89 MJ Posted June 20, 2022 Author Posted June 20, 2022 11 minutes ago, Gjeep said: One under each seat in all Jeeps. These actually have more juice than standard extinguishers. https://www.griotsgarage.com/ultra-compact-fire-extinguisher/?sku=26679&code=PPCPLG&gclid=EAIaIQobChMIpvn4wpS9-AIVICCtBh11GQxjEAQYASABEgI8NPD_BwE Thank you! I like how small it is!
Gjeep Posted June 20, 2022 Posted June 20, 2022 There’s a jay leno you tube video on this you should check out. Impressive.
89 MJ Posted June 21, 2022 Author Posted June 21, 2022 12 hours ago, Gjeep said: There’s a jay leno you tube video on this you should check out. Impressive. I will!
