Eriko5000 Posted April 21, 2022 Share Posted April 21, 2022 I replaced my valve cover gasket a few weeks ago, and upon pulling the cover, found significant gunk build up in the engine (See picture). I cleaned the valve cover out, and just put it back together. I've heard that Seafoam does wonders to break down build up inside the engine, but want to be sure if I put Seafoam in, that it dissolves it safely, rather than potentially breaking any pieces loose that might clog something. I'm also trying to figure out if there's an amount of build up that it's not worth cleaning out until you need to just do a rebuild. Any thoughts? Are there any other options for cleaning up the gunk build up safely? Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 21, 2022 Share Posted April 21, 2022 Could also run a little bit of ATF in the crank case too. But you shouldn’t have any issues. You could set an X amount of miles to run the sea foam and change it and see what it has done. Link to comment Share on other sites More sharing options...
Chad R Posted April 21, 2022 Share Posted April 21, 2022 Just like eaglescout said atf. Drain the oil and put 5qts of oil and 1qt of atf run it for a couple weeks or 100 miles which ever comes first and change the oil and filter. That’s what I have done Link to comment Share on other sites More sharing options...
89 MJ Posted April 21, 2022 Share Posted April 21, 2022 I have run a can of seafoam in my Eagle's 4.2 to try to clean it out some. I am also running it in one of my garden tractors. No issues to report here! The one thing to make sure you are aware of, though, is that it is thinner than the oil, so it will thin the oil out some. It will be a very minute difference, but it will still thin it out a tiny bit. It still will be fine for the engine. Link to comment Share on other sites More sharing options...
howeitsdone Posted April 21, 2022 Share Posted April 21, 2022 Like mentioned, you'll be fine. Just make sure to change the oil within about 25 miles so you get the gunk out and it doesn't sit in there. You can also take and add it to the brake booster vacuum line (unhook booster side) to clean the pistons and ignition system. That one can be tricky, but highly effective. Two other great brands for a pre-oil change clean are AMSoil & Liquid Moly. Both have an Engine Flush product that also work great. Link to comment Share on other sites More sharing options...
75sv1 Posted April 22, 2022 Share Posted April 22, 2022 I have done Sea Foam. 50 to 200 miles. I'd also look at Marvel's Mystery Oil. Youi can run the smaller bottle between OCIs. I have also done the Trans oil too. Up to 500 miles. I'd probably only do 200 miles though. I can't get a good read from your photos. Still, I'd replace the thermostat. 195F. If its like a grease, then your not heating up the oil enough and the water condensation is not being heated off. Also, synthetic oils will clean engines. Still, I'd worry about seal leaks. Also, I think Kroil has some engine cleaner. I've used it. I forget the results. I'd also see what condition your CCV system is in. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 22, 2022 Share Posted April 22, 2022 Substitute Marvel Mystery Oil for one quart of engine oil. Monitor the cleaning process through the oil fill hole. Run it til the next oil change if you want to. Link to comment Share on other sites More sharing options...
