Tracker Posted November 26, 2007 Share Posted November 26, 2007 I saw this thing sitting on the side of the road on the way to the desert this weekend. I didn't have time to check it out but I slowed down and took a pic. No answer at the phone #- Anyone know about year it might be?; possible axles and motor? I'm tempted. Link to comment Share on other sites More sharing options...
jeepinjay Posted November 26, 2007 Share Posted November 26, 2007 1980 Cherokee narrow track. 360 v8 or the inline six. The body alone is worth what they are asking if there is no rust. Link to comment Share on other sites More sharing options...
comancheon33 Posted November 26, 2007 Share Posted November 26, 2007 There is a twin to that at my local you pull it. Had a lift and everything on it. My cousin bought the front 44 and springs for 125 bucks. He's got a 69 waggy that is awesome. I would buy it for sure if it had the V8. Link to comment Share on other sites More sharing options...
jage Posted November 26, 2007 Share Posted November 26, 2007 looks like it might need tires. :) parting? building? restoration? what's your plan? Link to comment Share on other sites More sharing options...
Tracker Posted November 26, 2007 Author Share Posted November 26, 2007 Well, if it's newer than '75 I think I'll pass. That's the cutoff year for emission testing and vehicles from '76 to the first TBI's are nearly impossible to get smogged without major work. If anyone is interested or has a friend in SoCal, the area code for the phone # on the window is 661. The vehicle is sitting on Avenue "A", between 110th and 90th Streets West; just a little west of the city of Rosamond. Link to comment Share on other sites More sharing options...
jeepthing07 Posted November 26, 2007 Share Posted November 26, 2007 I would..... I love the 2 door Cherokees with frames! Link to comment Share on other sites More sharing options...
pingpong Posted November 26, 2007 Share Posted November 26, 2007 It should have d44's front and rear. Depending on yr.. it should have disc brakes upfront (flat top knuckles as well). If it is the 258 it should be mated to the 727TF. T-case will be a quadratrac, or a D20, maybe one of those Borq warner jobbies as well. To me it would make a great trail beater. Do a SOA swap, crossover steering, on say 35's or 37's. A nice cage... and cut the top off behind the driver.. and proceede to wail on it :brows: All told the only real money you would have in it is the cage, and tires, and the tires can go with you to your next beater. If you sold off the glass and sheetmetal to fanatics.. it could almost be free :nuts: Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted November 26, 2007 Share Posted November 26, 2007 That thing is no newer than 1979. Its got a Pignose grille. Last used in 1979. Specs can range from 360 2v/TH400/BW 13-39 3602v/ T-176 OR T-18a/ Dana20 Transfer. 258 /T15/D20 401/TH400/BW 13-39 (Otherwise known as a Quadratrac) 258/T-176/D20 It will have pass drop D-44 up front with a max gear ratio of 4.10 if you're lucky. More than likely its a 360/TH400 so it'll have 3.31's. 3.73 if its got a Tow pkg. Its a steal, pick'er up. If its got a Z code VIN, its a 401 rig. Search IFSJA for more on 401's haha. Link to comment Share on other sites More sharing options...
speed_racer Posted November 26, 2007 Share Posted November 26, 2007 401 = Drool.... Link to comment Share on other sites More sharing options...
JEEPERZ Posted November 27, 2007 Share Posted November 27, 2007 looks like a cool project to me. don't you need a project??? :D Link to comment Share on other sites More sharing options...
carnuck Posted November 29, 2007 Share Posted November 29, 2007 The front axle is the giveaway to what year range it is. RH drop is '79 and older (square headlights mean '77 or newer) and LH drop is '80 or newer. Cats weren't required till '78 (when 401 went away) because it's a truck. Vin code sez what motor was OEM. Z is 401, P is 360 (something else for 360 4 bbl), C is 258 aka 4.2L. Frame rot from the tin skidplated late model plastic fuel tanks happens just ahead of the left rear tire (from the inside!) It has no fender flares, so it's narrow track (not all flare fendered rigs are wide track tho!) Grills are swappable (some with a little extra work) from '63 to '91. T176 didn't happen till '80 (and had okay gearing) T5 sometimes came with 6 cyls from '80 to '88 with NP208 (I pulled mine because the synchros was supposed to be welded to the main shaft) Gearing is often 3.54 or 3.07 pre '80 (with 3.73 or 4.10 tow packages) '80 and newer got 3.31 and 2.72 Link to comment Share on other sites More sharing options...
