Jackrabbit41 Posted October 24, 2021 Posted October 24, 2021 So i need to do my fuel pump and i found a write up on here with these part numbers. Just wanted to see if this stuff looks right to you guys. when I look up the Airtex number, it gives me a fuel strainer rather then a fuel pickup kit. Any ideas? Bosch 69302 fuel pump kit Airtex FS104 fuel pickup kit Spectra Lo01 Lockring Kit w/seal Thanks!
Jackrabbit41 Posted October 25, 2021 Author Posted October 25, 2021 55 minutes ago, cruiser54 said: Only use Bosch. Do you know the other part numbers?
gogmorgo Posted October 27, 2021 Posted October 27, 2021 The strainer pretty well plugs directly onto the bottom of the pump, which I guess could be enough to call it a pickup kit. Which thread are you referencing? Bosch is definitely the go-to brand around here, for good reason. I’d recommend for sure getting all parts from the same manufacturer for a chance at compatibility. You’d only need to replace the lock ring if it was damaged, which is possible, depending on removal technique. The seal is just an o-ring, and it should come with the fuel pump.
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 Well my fuel pump came in and this thing looks completely wrong
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 The picture online showed it completely different
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 On 10/27/2021 at 4:33 PM, gogmorgo said: The strainer pretty well plugs directly onto the bottom of the pump, which I guess could be enough to call it a pickup kit. Which thread are you referencing? Bosch is definitely the go-to brand around here, for good reason. I’d recommend for sure getting all parts from the same manufacturer for a chance at compatibility. You’d only need to replace the lock ring if it was damaged, which is possible, depending on removal technique. The seal is just an o-ring, and it should come with the fuel pump. I don’t know the thread
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 1 minute ago, Jackrabbit41 said: I don’t know the thread On 10/27/2021 at 4:33 PM, gogmorgo said: The strainer pretty well plugs directly onto the bottom of the pump, which I guess could be enough to call it a pickup kit. Which thread are you referencing? Bosch is definitely the go-to brand around here, for good reason. I’d recommend for sure getting all parts from the same manufacturer for a chance at compatibility. You’d only need to replace the lock ring if it was damaged, which is possible, depending on removal technique. The seal is just an o-ring, and it should come with the fuel pump. i just have this picture
gogmorgo Posted October 29, 2021 Posted October 29, 2021 41 minutes ago, Jackrabbit41 said: You can’t copy and paste a link?
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 3 minutes ago, gogmorgo said: You can’t copy and paste a link? I’m trying to find it lol I found it over a year ago and took that picture
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 6 minutes ago, gogmorgo said: You can’t copy and paste a link? Here we go
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 Got my old one out. It’s a bosch 9580810019
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 Also wondering if anything is supposed to be on the lower fuel line where it looks like a hose could go on it
fiatslug87 Posted October 29, 2021 Posted October 29, 2021 If you apply 12v to your old pump directly does it spin? Nothing goes on that lower part.
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 3 minutes ago, fiatslug87 said: If you apply 12v to your old pump directly does it spin? Nothing goes on that lower part. Yes but check pressure at the rail and I was like 5 psi max
Andy in Pa Posted October 29, 2021 Posted October 29, 2021 I used the Bosch 69302 kit, it comes with everything you need. If you replace the pump and STILL have a problem, look up a post I made about this earlier this year. My problem was the ECU, not the pump. It was doing the same thing though, only pressurizing to 5-10psi on the fuel rail. In my case the fuel pump relay was buzzing too though.
Jackrabbit41 Posted October 29, 2021 Author Posted October 29, 2021 1 hour ago, Andy in Pa said: I used the Bosch 69302 kit, it comes with everything you need. If you replace the pump and STILL have a problem, look up a post I made about this earlier this year. My problem was the ECU, not the pump. It was doing the same thing though, only pressurizing to 5-10psi on the fuel rail. In my case the fuel pump relay was buzzing too though. I got the same kit but did you see the picture I posted? Thing looks so much different
