New Cargo Light Option
I like the idea of the ranger light, but the large hole, turns me off completely. Here are some surface mount LEDs that would be a lot easier to mount.
Amazon.com: Kawell Universal 2 Pack 6W LED Mini Light Bar Bumper DRL Fog Light Motorcycle Light DRL Tail Backup Light Car Motor Clearance Marker Lights for ATV SUV Mine Boat 4x4 Ford F150 : Automotive
  • 1 year later...
Hello Everyone. I just finished this install. I ended up using Harbor Freight’s Threaded Insert Riveter Kit with 1-4-20 Stainless Cap Head Fasteners. I had to drill out the mounting holes in the light to accept the 1/4-20 fasteners. I fashioned a gasket out of two pieces of red colored rubber sheets that are located in Lowes Plumbing department.
how on earth is it that I can't find a 3rd-brake/cargo-light unit that's flush mount?  everything that I find has depth and requires cutting a giant hole.  :fistshake2:  and things that are flush only do brakes or cargo.
and yes, I'm sure it's because they are simply replicating factory units (where the trucks already have the hole).  I'm just frustrated that more people aren't looking to custom wire their trucks to justify the aftermarket getting off their butts and making the thing I want.  :laugh:
Ah, got it. And the wire that you run, did you run it above the headliner over to one of the B pillars? How much space is there between the headliner and the roof? Just trying to understand if I can put a Weather Pack connector in between the light and the wires that I'm going to run to the switch.
