Finally got the last piece I needed to complete this wall hanger.
Anyone actually hang one of these?  I want to make some sort of bracket to secure it to the wall, rather than just set it on or hang it from screws.
I’ve been thinking about using something like these to hang a couple of mine. 2 on the bottom and one on the top but I haven’t tried it out yet
12 hours ago, fiatslug87 said:
I would try to use the four attachments points that bolt it to the fenders, that way no fasteners/brackets are visible.
The problem is the headlight buckets stick out the back quite a bit.  The fender mounting points do not sit flush against the wall.  I'm not going to mod the parts, I might need to bolt them on someday!
I screwed the fascia to a 2x4 to bump it out enough to clear those buckets and the bumper caps (was planning on mounting the bumper too).  I didn't snap a pic of it though and it'll be a couple more days until I'm back in GA.
Hmmm I have a spare bumper
Then all you need is a lower valance/airdam thing beneath the bumper and the lower front part of the fenders to go on the end of that.
All painted in that beautiful blue on the header.
  • 4 weeks later...
