ktmall07 Posted September 3, 2021 Share Posted September 3, 2021 Hey all, My parking brake pedal won't stay engaged, almost like the release won't disengage completely (I can hear the teeth catch, but then it almost immediately slips along the teeth with a CLACK-CLACK-CLACK sound and the pedal releases completely). Any ideas? The brake itself works, I've tested it multiple times, it's just that the pedal won't hold, so if I want the brake to be engaged full time, I have to hold the pedal down myself, which, for obvious reasons, defeats the purpose of a parking brake to begin with Link to comment Share on other sites More sharing options...
watchamakalit Posted September 3, 2021 Share Posted September 3, 2021 There is a spring on the very top of the pedal mechanism that keeps the ratchet paw engaged. Check that it hasnt come unhooked. I had that problem on mine. Link to comment Share on other sites More sharing options...
ktmall07 Posted September 3, 2021 Author Share Posted September 3, 2021 Do you mean the spring connected to the release handle? That's still working fine it seems, am I missing another spring? Link to comment Share on other sites More sharing options...
Pete M Posted September 3, 2021 Share Posted September 3, 2021 not sure if this would be the cure, but the link in my sig should have a writeup on refurbishing the teeth on the catch gear. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 3, 2021 Share Posted September 3, 2021 Refurbished e brake units should be finding their way to the vendors section shortly Link to comment Share on other sites More sharing options...
ktmall07 Posted September 3, 2021 Author Share Posted September 3, 2021 I ended up replacing the old spring connected to the release handle, and found that the teeth are very worn, but the pedal seems to hold now! We'll see if it's still having problems in a week haha @ghetdjc320 I might hit you up on that if I'm still having problems! Link to comment Share on other sites More sharing options...
Minuit Posted September 4, 2021 Share Posted September 4, 2021 The factory parking brake mechanisms suffer from a design flaw (my guess is improperly hardened ratchet teeth) that basically means EVERY MJ parking brake mechanism will do this eventually. This was the subject of a recall for 1986 models, but it's present in all of them. You can refinish the teeth and add stronger springs, but my guess is that it's probably going to happen again. I'll be converting my 89 to a hand parking brake for exactly this reason. No way I can trust them again after seeing pictures of some of the worn teeth. Link to comment Share on other sites More sharing options...
