Everything posted by ktmall07
When I did this repair, the passenger side had rusted through all the way back through and on both sides of the raised beam on top of the frame rails, so it was a ton of extra work to make a new one and try and salvage the seat mounts. Hopefully you don't have to do that! The front section closer to the firewall was not as difficult to reach or repair, especially if you're just cutting out a flat piece and seam welding. Just make sure to not weld in a straight line but tack weld in a clocklike pattern (similar to tightening lug nuts, so maybe start with corners, then ) so that you don't warp/melt through your new piece. After welding new pieces in and grinding it relatively smooth, I covered everything in POR-15 and left if for a few days to really solidify so I wouldn't have the problem any more in the future. Obviously fixing leaks is the real way to prevent it from happening again, but while you have everything taken out you might as well to be extra sure!
Fender Flare + Liner Options
ktmall07 replied to ktmall07's topic in MJ Tech: Modification and Repairs
Thanks! -
I'm sure this has been asked before, but what have people done for replacement fender flares and liners? I'm assuming that any front liner or flare from an XJ from the same years would work, but what about rear? Any custom builds?
Thanks for the tip! I ended up pulling the driveshaft today to inspect and couldn’t find anything wrong with either the slip yoke or the output shaft, or the seal. I did end up finding one of the retaining clips was not all the way in on one side of the flange adapter. I used a press to make sure the u joint was all the way centered in the adapter, and replaced the clips with new ones on both sides. I replaced the driveshaft and vibrations decreased by like 90%, now there’s no more vibrations at high speed than low speed. Lesson learned to make sure u joints are centered and retaining clips are in all the way! Haha 😅
Hi all, I recently completed an 8.8 swap, and installed a rusty's 3" lift front and rear at the same time, and have since had some driveline vibrations at high speeds (> 55 mph). I've narrowed the vibrations down to the rear driveshaft, and checked u-joints first (both were replaced on installing the new axle, and seem fine, they're a few months old). The new 8.8 flange adapter is in good shape as well, it was brand new when purchased, and nothing on that end is loose/worn. I did not install a slip yoke eliminator, because my lift height is not extreme, and pinion/t-case angles are close enough to have almost no slow-speed angle-related vibrations. When inspecting the slip yoke, it seems that pushing up on the driveshaft right below the u-joint causes the transfer case output shaft to move just a hair (< 1/8", just enough to be noticeable). The movement is only up/down, not side-to-side, no matter the position of the u-joint/drive shaft. Maybe the lift itself has put just enough pressure on the bottom of the output shaft to bend something? My question is: Is any amount of lateral movement in the output shaft normal? I've read that excessive movement could mean a worn tailhousing bushing/seal? There's no real leak from the tailhousing (or the transfer case generally), so not sure if either of those things being worn would be noticeable enough to diagnose without pulling it apart. I also haven't taken off the slip yoke since I reinstalled it. I can't tell if the movement is from the output shaft itself or the slip yoke, but it seems like the movement is from the output shaft (when pulling in different directions, I can't move the slip yoke at all, there's no play in it on the end of the output shaft I don't think). If I have to take everything apart to check anyways, Is an SYE necessary/worth it? I thought I was good without one since the lift was not extreme, but maybe better safe than sorry? Any input would be appreciated. Thanks!
Ford 8.8 Swap Brake + E brake Setup
Thanks guys! -
I’ve got an 8.8 out of a 99 Explorer (therefore disk breaks) prepped and ready to swap, but the one thing I haven’t figured out is the new brake setup. For those who have done the swap, what did you do for brake fittings? Did you replace lines or could you get away with using stock setups and replacing fittings only? I also don’t currently have a working parking brake, but I’ve got everything setup on the 8.8 to reinstall it. The teeth are stripped on my parking brake pedal, so I was thinking of fabricating a bracket to let me use a handbrake from an XJ. Has anyone done a similar project? Has anyone installed a new parking brake cable for an 8.8 on their truck?
A/C Receiver Drier to Expansion Valve hose
That’s what I’ve decided. I cut out the fittings from the old hose and crimping, and am taking it to a shop to have a custom one made. Thanks guys! -
I’m finally finishing up an A/C retrofit, and I’m kinda stuck. The truck didn’t have A/C originally, but had a dealer install a generic system some time. I’ve replaced everything with a mostly stock system, except for the expansion valve, which I replaced with a new version of what was originally on there (some 4 seasons part) because to fit a stock expansion valve I’d have to tear into the firewall Andy replace the whole system, and I want to avoid that until I can’t. I need a new hose from the receiver drier to the expansion valve, with the same fitting on both sides unlike the stock system that has the thin fastener on the expansion valve side. Has anyone seen a hose like this, and does anyone know where to find one? I need a longer version of the hose on the left in the first picture, on the right is a stock hose that is long enough, but has the wrong fitting on the expansion valve side.
Was walking to the bus stop after class today, and look what I found parked on campus! Not a great picture, but if I see it again, I'll stop and get better ones!
Replacement Harmonic Balancer?
Will it fix all the other problems with my engine for that price? haha -
I know there's a difference between the original 33002920 Harmonic Dampener and the newer ones (33002920AB or 33002920AC). Has anyone had any experience with the Crown parts Harmonic Balancer, CRO33002920? Is it factory spec to the old HB or updated one? Getting ready to replace the HB, and I'm comparing options. If anyone has had good luck with aftermarket HB's that haven't needed modification like shearing off the end, or removing the "oil slinger" inside the timing cover, I'd be interested to know it. I'd like to avoid Dorman if at all possible, but I'm willing to consider it if other people have had good luck with theirs.
Just replaced the radiator with a CSF 2671 all metal radiator, and now I've found it's leaking from the lower rad hose on startup, but the leak stops after the truck warms up. Seems like there's incorrect pressure at the hose fitting until the truck heats up. I've checked the hose itself, and tightened it as much as I can, but the leak continues only for the first few minutes after the truck starts cold. Any ideas?
What's the difference between the 708 and the 709? The compressor on my truck now is a 709t. I can find other 709's, but not a 708 for a 92.
I'm looking to replace my compressor as part of an R134a retrofit, do I need to get a specific compressor, or will a stock replacement do? (I know that replacing the compressor is not mandatory, but mine has sat for years without running so better safe than sorry!)
AC Expansion Valve Retrofit Question
I think I've found an exact match for the expansion valve, made by 4 Seasons. Has anyone used their products before? https://www.carparts.com/details/Jeep/Wrangler/4-Seasons/A-fs-C_Expansion_Valve/1992/FS38683.html?TID=gglpla&origin=&utm_source=google&utm_medium=pla&utm_campaign=12885424929&gclid=Cj0KCQjwlK-WBhDjARIsAO2sErQrUQQUw6FzATYNT1jAId_JBzKbRJAYfwin28Xuql82EYqEh1Z_FkcaArCyEALw_wcB&gclsrc=aw.ds After doing some more research, it seems like the whole system might be a dealer kit for a YJ. I'm a little confused as to why YJ parts were used when XJ parts are literally identical to an MJ, but who knows. I'm at least one step closer. Only problem now is the compressor. I'm planning on getting a new one, but can't find a compressor with a wire socket that looks like this: Anyone seen this before? -
@cruiser54 if I just left the original valve in and replaced the O-rings on both hoses at that end, should that be good? Is there anything else I need to replace to stop leaks? -
That's not a bad idea. I don't know how long the whole system sat without working, so I'm planning on replacing pretty much everything except the hoses, which look in good shape. My question is, can I really just swap out the parts from a factory HO kit? The lines coming out of the firewall are in different spots than where they're at on a factory HO setup. I'm worried that I'll open a can of worms digging into the firewall just to find out that there's no way to rearrange the lines themselves to fit. -
Yeah, that's the one! I'm not sure when the kit was installed. All I've found online are the block style as well. I'll keep my eyes out though! -
I'm reasonably sure it was installed by a dealer, just at a later date than when the truck was originally purchased. So any expansion valve that's good for r134a should work out? -
Hey all, I'm working on an AC retrofit, but the truck never came with AC, someone installed it at a later date. Almost everything is the same as a stock truck with AC, except the expansion valve, shown in the picture below. It looks like a pretty basic valve, minus the block that comes on the stock expansion valve. I can't find any no name brands with valves that look quite like this one, and there's no part number that I can see. Anyone seen this before? If there's no way to get a new one, is it really mandatory to replace it? Or could I just replace the O rings on both fittings and get away with it?
I'm determined to fix the AC in this truck, and I've found out that the AC relay is blown. The catch is, this truck didn't have AC from the factory, but was installed by possibly a dealer(?) sometime after it was purchased. Here's some pictures showing the setup, and the six-pin relay, and the part number. It seems like the radiator aux fan only runs when power is sent through this relay, (doesn't make sense to me either, I'm just trying to figure out what on earth is going on here haha ) How close is this to the stock setup? Is this relay used on all 92 xj's and mj's? I compared this to the system on a 2001 xj, and it's totally different, but I don't know if that's because a lot changed between 96 and 97, or if mine is just a solitary mess If this relay is in everyone's rigs (that has AC), anyone know where to find it? No parts/hardware shops around here have relays like this one.
Engine Temp Drops In the Cold
@Minuit any tips on where to find a Mopar thermostat? Everywhere I've looked says you can't buy them anymore. -
I'm an idiot. I meant coolant temp gauge, but somehow I typed oil temp both times haha There's plenty of coolant, I just flushed and refilled a month or two ago, and checked up on it before my trip last week. Fan clutch seems good. No wiggle room in the fan, and I couldn't rotate it much before starting the truck this morning. I wonder if maybe an air bubble has gotten stuck and I just didn't spend enough time burping the system after the flush? I'll have to check, but the thermostat could probably use replacing anyways. Thanks for the help!
