Project “Tomahawk”
The gauge cluster is officially in the hands of the Dakota Digital custom shop. Estimated turnaround is 2–3 months, but there’s no rush on my end.
I’ve requested that the temp, voltage, oil pressure, and RPM sweeps match the C5 Corvette layout, while preserving the overall Jeep gauge arrangement. The speedometer will read to 160 mph (no, it’ll never see that speed), and the KPH markings will be deleted.
We’re planning to retain the original Jeep font and incorporate the tomahawk emblem I designed—positioned just above the needle pivot, echoing the placement of the checkered flags on the C5 cluster. The temperature gauge will center at 220°F, just like the OE Corvette, aligning perfectly with the factory thermostat and fan settings I’ve kept in place.
The cluster will use a CAN bus module to pull data directly from the ECM using the original sensors—again, mirroring the Corvette’s approach. Factory warning indicators like the check engine and upshift lights will remain in their stock locations. However, the turn signal and high beam indicators will now be integrated into the gauge face itself, eliminating the need for bezel-mounted lamps.
A compact OLED display will also be added to the dash, compatible with Dakota Digital’s HDX BIM modules for real-time readouts like TPS, AFR, EGT, and more.
I’ll post renderings once they’re ready—really looking forward to seeing what they come up with.
  • Replies 843
Maybe I missed it, where are you connecting the new cluster? Will it be OBDII based or run directly off of the ECU?
I’m actually not sure yet. The cluster will read the data from the ecu but it has an obd2 connector. If I do end up using the obd2 port, I’ll see if I can run some sort of splitter for it so I can still connect other things like the HP tuners to it. I like the idea of seeing exactly what the ecu sees without having to run auxiliary sensors all over the place.
totally agree,
I have seen use of OBD port splitters before. I know its not an uncommon thing.
On 12/5/2025 at 6:30 PM, ghetdjc320 said:
I find myself still taking pictures of my own truck that I’ve been daily driving for months now :laugh:. Every once in a while it hits that perfect stance look.
Looks great!
What's the story on the winch hook? (or lack of one)
2 hours ago, Comanche SS said:
Looks great!
Actually wanted to fit a factor 55 Seth there but just haven’t gotten around to it. The winch line is actually behind the bumper fairlead for now to keep it out of the elements. I didn’t want the hook sitting there rattling. I have the d rings as well but needed to get the bushing kit to keep them from rattling also.
Gotcha, rubber hose works as a bushing and for much less usually. I'm too cheap lol
  • 2 months later...
Unexpected but not unwelcome :L:
Also been working with Dakota a digital to design a set of custom HDX gauges for the truck. Trying to keep the factory layout and design in tact vs all those “digital dashes” I keep seeing swapped in. I had all gauges except for the fuel and speedometer match the factory C5 corvette scaling so the engine readings will match. I’ll be pulling all the data from the ecu via the OE ls sensors for accuracy. The HDX gauges come with some little oled displays in the fae of the RPM and Speedo but we’re removing those fo a clean gauge face and sticking those two screens in the warning light section of the dash. There I can see tpms, fuel pressure, and a great deal of aux data as needed. That lets me keep the 270* gauge sweeps for the speedo and rpm. I also went 180* sweeps for the other gauges to match the C5 and add some more gauge resolution. Still need to finish the gauge faes and remove the redundant turn signals in them but really liking this layout design. The cluster build should be done this next month
For good or heading back to the island in the future?
That cluster will look great! Thank you for not just swapping to a digital screen. This will look so much more correct in the truck.
Its indefinite for now. Have a little one on the way so we transferred stateside :L:
Congratulations! Time to add an XJ to haul everyone :laugh:
  • 3 weeks later...
Had to make a few adjustments to the gauge layouts. I wasn’t super keen on losing the indicator lights on the left side of the dash so we reworked the layout somewhat and this is the new final. Still holding true to the original but with all the modern functionality. Those small oled screen in the gauge faces will be the aux readouts with multiple data streams they can display while still keeping the nice symmetrical analog gauges. We’re also going to keep the oe locations for the turn signal and high beam indicators albeit with custom led housings to make it look original (ultimately this is a simple felt gutted cluster).
  • 3 weeks later...
Took the MJ in to a local shop the other day to have them fix the buggerred drivers side down pipe the local butcher/muffler shop installed. Had a piece of mig wire 6” long sticking out of the side of the pipe near the flange. What a joke. Horrible routing and I hadn’t even noticed they had reduced down to 1.75” tubing. So I picked up a pipe of 16awg 304 stainless pie cuts along with some mandrel bends and v bands.
On another note, I was experiencing some death wobble whenever I hit a bump while going 35+ mph. Fairly violent as well. I inspected all the steering and suspension components and didn’t find any issues so I dropped it off for a good alignment. They fixed the toe and it seems to have resolved the issue. I’d still like to swap in an iron man fab track bar system for the double sheer bracket and the cross brace. That and maybe the Curie Curectlync and some of those new metal cloak ball joints :cool:
