Ax15 swap troubles and questions
  • Replies 69
16 minutes ago, Pete M said:
hey, do you remember the socket size for the transmission crossmember bolts?  I've discovered my knee won't let me get down on the ground in the barn to check my own truck.  :laugh:
If I remember correctly the crossmember-to-frame bolts are M10x1.25 so they would be 17mm.
39 minutes ago, Pete M said:
don't you have an ACE or Aco hardware store nearby?  something?  anything?!  :dunno:
my ace sucks. nut and bolt supply had everything other than hardened all thread. I picked up some big beefy 3/4 inch bolts for my steering
thats so cool.
got it in today mostly headache free! just need to do all the accesories and then do the pedal and master asembley and it will be "driving". I did already break 2 bits trying to drill the old roll pin out of the old master so I can use the clutch line with my new master. also I still can seem to figure out the "quick disconnect" fitting on the slave side
