Muncher Posted June 18, 2021 Share Posted June 18, 2021 So my lights are coming in today for my roll bar. To people who have then how did you run the wires? Is there a way to get them inside the factory roll bar and through the bed because I'd like to have them not exposed Link to comment Share on other sites More sharing options...
fiatslug87 Posted June 18, 2021 Share Posted June 18, 2021 (edited) The factory roll bar has holes at the top where the lights attach and a hole in the driver's side front mount. You'll have to drill a corresponding hole in the bed and fish the wires up (or down). I'll look for the installation instructions and post them here. MJ Sportbar Lights.pdf Edited June 18, 2021 by fiatslug87 Installation instructions attached Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 18, 2021 Share Posted June 18, 2021 27 minutes ago, fiatslug87 said: The factory roll bar has holes at the top where the lights attach and a hole in the driver's side front mount. You'll have to drill a corresponding hole in the bed and fish the wires up (or down). I'll look for the installation instructions and post them here. MJ Sportbar Lights.pdf 69.22 kB · 1 download Oooo that’s a good one. Link to comment Share on other sites More sharing options...
Muncher Posted June 18, 2021 Author Share Posted June 18, 2021 The factory roll bar has holes at the top where the lights attach and a hole in the driver's side front mount. You'll have to drill a corresponding hole in the bed and fish the wires up (or down). I'll look for the installation instructions and post them here. MJ Sportbar Lights.pdfThank you! Link to comment Share on other sites More sharing options...
Muncher Posted June 20, 2021 Author Share Posted June 20, 2021 So how exactly am I supposed to get all that wire In the roll bar?? Link to comment Share on other sites More sharing options...
jdog Posted June 21, 2021 Share Posted June 21, 2021 https://www.homedepot.com/p/Klein-Tools-Glow-Fish-Tape-20-Foot-50550/314609744 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted June 21, 2021 Share Posted June 21, 2021 If there isn’t a small hole in the bar below the light I’d make one. Run a smaller single wire and fish it from the top down. Use that as a pull wire Link to comment Share on other sites More sharing options...
Muncher Posted June 21, 2021 Author Share Posted June 21, 2021 If there isn’t a small hole in the bar below the light I’d make one. Run a smaller single wire and fish it from the top down. Use that as a pull wireI'll try that. I think I need to take the roll bar off and put a whole under the bed Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted June 21, 2021 Share Posted June 21, 2021 Once you have a hole in either end for the wire, get a long piece of string and a shopvac. Feed the string down the first hole, put the shopvac at the other end and turn it on. Use that string to fish/ pull the rest of your wires through. Link to comment Share on other sites More sharing options...
