Muncher Posted May 14, 2021 Share Posted May 14, 2021 These were behind my bumper what are they for? Also there was some weird metal block in front of the steering gear is that supposed to be there ? Link to comment Share on other sites More sharing options...
Dzimm Posted May 14, 2021 Share Posted May 14, 2021 Looks like it's just a reinforcement plate for the bumper mount and uses real nuts instead of the stupid metal clip on things. Do you have a picture of the other block you are talking about? Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 Looks like it's just a reinforcement plate for the bumper mount and uses real nuts instead of the stupid metal clip on things. Do you have a picture of the other block you are talking about?No I don't. I'll have to take one tommrow when I get back to working on it Link to comment Share on other sites More sharing options...
scaleless Posted May 14, 2021 Share Posted May 14, 2021 The block is supposed to be there, yes. It's there to deflect the box in case of a front-end collisions so the steering shaft doesn't, like, spear through the driver.They removed it in the HO years. Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 The block is supposed to be there, yes. It's there to deflect the box in case of a front-end collisions so the steering shaft doesn't, like, spear through the driver.They removed it in the HO years. Ohh ok. I had to remove the cross member so I took it out Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 14, 2021 Share Posted May 14, 2021 That plate looks like part of the tow hook re-enforcement plate set up. Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 That plate looks like part of the tow hook re-enforcement plate set up.It had them factory so maybe Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 14, 2021 Share Posted May 14, 2021 Here's a pic of the brackets for the tow hooks, your bracket is circled. Link to comment Share on other sites More sharing options...
89 MJ Posted May 14, 2021 Share Posted May 14, 2021 I second them being for the tow hooks. I had some similar from my truck that had them, my other two don’t. Link to comment Share on other sites More sharing options...
AZJeff Posted May 14, 2021 Share Posted May 14, 2021 Those brackets are useful if you install a larger/heavier front bumper, tow hooks or not. Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 Those brackets are useful if you install a larger/heavier front bumper, tow hooks or not.I have a hidden winch I'm putting in. I'm gonna try to keep them maybe Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 14, 2021 Share Posted May 14, 2021 Which hidden winch mount are you using? Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 Which hidden winch mount are you using?Baddadfab btsd very high quality Link to comment Share on other sites More sharing options...
scaleless Posted May 14, 2021 Share Posted May 14, 2021 14 minutes ago, Muncher said: Baddadfab btsd Took me a while to figure out you weren't randomly slapping your keyboard lmao Link to comment Share on other sites More sharing options...
Muncher Posted May 14, 2021 Author Share Posted May 14, 2021 Took me a while to figure out you weren't randomly slapping your keyboard lmao Link to comment Share on other sites More sharing options...
