500 MJ Posted April 27, 2021 Share Posted April 27, 2021 I purchased the tail lights and radio from this truck online. VIN came on the receipt. Truck is located at Butchko Brothers in Dunbar PA. They were a very helpful yard to deal with on the phone, they seem to ship lots of parts out... . Link to comment Share on other sites More sharing options...
jdog Posted April 27, 2021 Share Posted April 27, 2021 Build: October 2, 1991 Body: TL61 Selling Dealer: BENKE MOTORS INC GIBSONIA, PA *C1 DESCRIPTION NOT AVAILABLE -SA Charcoal ARLP BARP 90 Amp Alternator BCDP 500 Amp Maintenance Free Battery CBAP Straight Back Bench Seat CKAP Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case DRKP Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle ERH 4.0L I6 Power Tech Engine GEC Front Left Side Sliding Window GFDP Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZP Manual Remote Mirrors HAA Air Conditioning JHAP Var Intermittent Windshield Wipers JJAP Cigar Lighter KKSP STRIPE/BADGE/MOLDING/COLOR K2BP STRIPE/BADGE/MOLDING/COLOR K27P Do Not Use MBJP Black Bumper MHAP Black Windshield Moldings MMKP Lower Grille Surround-Painted Silver PW7 Bright White Clear Coat RAAC All Radio Equipped Vehicles RAFP AM/FM Cassette Radio RCDP 4 Speakers SBAP Power Steering SUA Tilt Steering Column TBBP Full Size Spare Tire TMWP Tires TZAP Goodyear Brand Tires WJDP 15X7.0 Styled Steel Wheels WLYC All Steel Wheels YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z58P Left Front Spring Group Viii Z78P Right Front Spring Group VIII 2TEA Customer Preferred Package 2TE 26E Customer Preferred Package 26E 3VRA Customer Preferred Discount 4HA Special Scheduling Condition I APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DMDS 3.55 Rear Axle Ratio GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass JAZS DO NOT USE - See JP, KA classes JCAS 85 MPH Primary Speedometer KWSS STRIPE/BADGE/MOLDING/COLOR K3WS STRIPE/BADGE/MOLDING/COLOR LBCS Glove Box Lamp LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MMCS Rear Door Solid Window Insert MMGS Belt Moldings NAAS Federal Emissions NBKS EVAP Control System NF2S 18 Gallon Fuel Tank QW7S Bright White Clear Coat SCES Wrapped Steering Wheel SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch XBSS Pickup Box YAAS Build To U.S. Mkt. Specifications Z1AS GVW/Payload Rating 1AAS U.S. Dealer Retail 143S Zone 43-Pittsburgh Link to comment Share on other sites More sharing options...
Pete M Posted May 4, 2022 Share Posted May 4, 2022 @500 MJ is this truck 2wd or 4? Link to comment Share on other sites More sharing options...
500 MJ Posted May 5, 2022 Author Share Posted May 5, 2022 No idea. I can’t find its listing anymore to try and look through any remaining photos either… could decoding the VIN help any? Link to comment Share on other sites More sharing options...
Pete M Posted May 5, 2022 Share Posted May 5, 2022 FT should be a 2wd, I was just hoping to confirm since my book only does 87-90 and this is a 92. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 6, 2022 Share Posted May 6, 2022 DHT Elec,Shift-on-the-Fly,P/Time T/Case Found this on the build sheet in starparts. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 15, 2022 Share Posted May 15, 2022 @Pete M if you look at the registry list in the "VIN_Codes" sheet you can decode all VINs which includes 2WD/4WD. Another way is the Body code listed by the build date, a T is 2WD, a J is 4WD for all MJ production years. Link to comment Share on other sites More sharing options...
