Delee Posted April 8, 2021 Share Posted April 8, 2021 Hi I'm redoing a mj with the h.o 4.0 and the tank and pump was wasted so I bought a new tank but I can't find the right sending unit rockauto ,autozone, advance, orileys, nor anything I've seen on the net looks like mine ..my float and strainer point to the left of the inlet hole all others I've seen go to the right and will not fit with the tray in the bottom of tank.. I'm at a loss I've even bought a xj sending unit no luck there either..any help would be nice Link to comment Share on other sites More sharing options...
Torq_Shep Posted April 8, 2021 Share Posted April 8, 2021 There is none. The only reasonable option you have for a 1991 is to send it to https://tristarrradiator.com/ for rebuild. There is a post somewhere of someone hacking together two MKS units to make a 1991 "new" unit but that seems a bit overkill. You could ask if they want to do 2 of the same style and I could send mine in as well =P Maybe get a discount. Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 8, 2021 Share Posted April 8, 2021 Many people have had a very good experience with TriStarr, including myself. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 10, 2021 Share Posted April 10, 2021 Me too Link to comment Share on other sites More sharing options...
Snowstorm87MJ Posted April 12, 2021 Share Posted April 12, 2021 Not sure if they changed them after 1990 but this company Manufactures sending units for the MJ's https://www.mtscompany.com/sendingunits.htm Link to comment Share on other sites More sharing options...
Pete M Posted April 12, 2021 Share Posted April 12, 2021 3 hours ago, Snowstorm87MJ said: Not sure if they changed them after 1990 but this company Manufactures sending units for the MJ's https://www.mtscompany.com/sendingunits.htm yes, they changed in 91 Link to comment Share on other sites More sharing options...
bruce9 Posted April 12, 2021 Share Posted April 12, 2021 I just purchased a comlete new assembly Link to comment Share on other sites More sharing options...
Snowstorm87MJ Posted April 12, 2021 Share Posted April 12, 2021 29 minutes ago, Pete M said: yes, they changed in 91 ah, alright.. leave it to chrysler to change the parts ever so slightly. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 12, 2021 Share Posted April 12, 2021 48 minutes ago, bruce9 said: I just purchased a comlete new assembly For a 91? Where were you able to find one? Link to comment Share on other sites More sharing options...
DesertRat1991 Posted April 13, 2021 Share Posted April 13, 2021 4 hours ago, bruce9 said: I just purchased a comlete new assembly Pics..? Link to comment Share on other sites More sharing options...
bruce9 Posted April 13, 2021 Share Posted April 13, 2021 well, I got screwed. I purchased it from Advanced Auto. received it and just went to install it and found the sending unit and strainer are located on the wrong side. plus the hanger has it sitting a bit shallow so it doesn't locate at all. I called Carter and spoke with them and they quit building the assemblies for these. You can get the pump (higher pressure and GPH than Cherokee?) but no complete assembly. So I need to rebuild the existing assembly. Sorry for the misinformation. And my MJ is a '87 4.0 2wd Link to comment Share on other sites More sharing options...
bruce9 Posted April 13, 2021 Share Posted April 13, 2021 Being the researcher I believe that I am, I followed the link above to MTS, Spoke to Steve and YES, they offer a complete assembly. They were extremely helpful. **NEW** 1987-1990 Jeep® Comanche MJ 18 & 23.5 gallon "side mounted" gas tank sending unit with fuel injected engines (w/ pump) for the 4.0L engine. Includes new lock ring and O-ring. Replaces # Top Plate View: pic 2 Ohm range: Full 80-90, Empty 0-10. Available in 3-5 weeks (Mine is on order) $151.95 plus shipping Link to comment Share on other sites More sharing options...
