is 588 good?
gixxerman600
Is that your RTI score? Behonest ramping rigs has kinda gone the way of the past, or mall crawling ;) BTW lockers have nothing to do with yor score... they are suppose to stop once you start binding on something, and by the looks of it.. your front tire should have some custom grooves cut by now :brows:
It's hard to compare an MJ to an XJ as the wheelbase is different, thus affecting the score. It is also relative to what degree ramp your running on.
A club member at the last event had an XJ with a 3" lift and 31's scored a 533. Based on the fact you have longarms I'd say that 588 is kinda sad.
Did you lift your rear tire or just stop due to the rubbing in the front fenders?
