Muncher Posted February 26, 2021 Posted February 26, 2021 I jusy got a battery cable kit and started putting them in today. I could use some help identify things. I've got one cable going from the relay to the pdc but am unsure where the pdc is. I have a renix motor if rhat helps. Thank you
jdog Posted February 26, 2021 Posted February 26, 2021 Don't have one, you should have a cable from the battery to the starter relay
Muncher Posted February 26, 2021 Author Posted February 26, 2021 12 minutes ago, jdog said: Don't have one, you should have a cable from the battery to the starter relay Ok thanks. I do have thay. I dk have a fuse it came with so maybe it goes to that?
Muncher Posted February 26, 2021 Author Posted February 26, 2021 Ok so I re did all my cables and I put them all in and put the battery in and now it won't start. I have power inside but won't start. I had to change the neagitve cable to a different part of the block but besides that everything is the same. What could be wrong ?
Muncher Posted February 26, 2021 Author Posted February 26, 2021 Thinking maybe a bad neagitve battery cable ground but at the same time I do have power in the cab so I'm not sure
Pete M Posted February 26, 2021 Posted February 26, 2021 did you clean up all of the connections at the starter relay?
Muncher Posted February 26, 2021 Author Posted February 26, 2021 1 hour ago, Pete M said: did you clean up all of the connections at the starter relay? Starter is brand new.
Muncher Posted February 26, 2021 Author Posted February 26, 2021 23 minutes ago, jdog said: does it crank? Usualy it does. But now I jusy have power inside and when I turn the key nothing happeneds
jdog Posted February 27, 2021 Posted February 27, 2021 Double check that all the connections are on the starter relay
Muncher Posted February 27, 2021 Author Posted February 27, 2021 11 minutes ago, jdog said: Double check that all the connections are on the starter relay There's just one positive on the starter though ir are you talking about something else ?
jdog Posted February 27, 2021 Posted February 27, 2021 the starter relay is on the fender near the battery, it should have 4 terminals and like 5 wires on one terminal
Muncher Posted February 27, 2021 Author Posted February 27, 2021 28 minutes ago, jdog said: the starter relay is on the fender near the battery, it should have 4 terminals and like 5 wires on one terminal Oh ok. I know I put the alternator wire on there and the one from the positive terminal to it. There was a couple of other ones on there 2 but ill see tommrow if there's any loose ones.
ghetdjc320 Posted February 27, 2021 Posted February 27, 2021 Is this a battery cable kit your trying to install?
ghetdjc320 Posted March 1, 2021 Posted March 1, 2021 Awesome. What was the missing cable/ground you needed?
Tex06 Posted March 2, 2021 Posted March 2, 2021 On 2/26/2021 at 5:45 PM, fiatslug87 said: Maybe this thread will help. Might not. I've a 92 so H.O., not Renix.
Muncher Posted March 2, 2021 Author Posted March 2, 2021 21 hours ago, ghetdjc320 said: Awesome. What was the missing cable/ground you needed? I just put in the fuse cable and I had one small wire on the distributor block that I missed
