88mjsally Posted December 31, 2020 Share Posted December 31, 2020 Found this truck this summer and forgot to grab the vin from the front radiator support since the dash vin is unreadable. It has ho visor clips, bench but it’s a Renix 4.0 so I’m guessing late 90. Still has a nice short bed that I may go back and grab Link to comment Share on other sites More sharing options...
jdog Posted December 31, 2020 Share Posted December 31, 2020 @eaglescout526 @JMO413 can you pull the last 8? should be LL153078 Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 31, 2020 Share Posted December 31, 2020 Yeah I pulled the last 8 this morning. You are correct. It was built in 10/4/89. Link to comment Share on other sites More sharing options...
jdog Posted December 31, 2020 Share Posted December 31, 2020 sucks as mine shows a 20 gladiator, if you would post the correct vin ill get a build sheet going Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 31, 2020 Share Posted December 31, 2020 Yeah I saw the JT too which means some 90’s are now gonna conflict with 20 JT VINs. Nothing too major of an issue. But on your end it will be tough unless you have the full. Link to comment Share on other sites More sharing options...
88mjsally Posted December 31, 2020 Author Share Posted December 31, 2020 Yea I can’t read the dash vin or the door vin so that tag was all I could see Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 31, 2020 Share Posted December 31, 2020 Can a build sheet be pulled or is it lost? @eaglescout526 Link to comment Share on other sites More sharing options...
jdog Posted December 31, 2020 Share Posted December 31, 2020 Yeah he can get it with the last 8 his will show both vehicles Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 31, 2020 Share Posted December 31, 2020 My '90 also comes up with as 2020 Gladiator. Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2020 Share Posted December 31, 2020 just when you thought Jeep couldn't make our lives any harder... Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 31, 2020 Share Posted December 31, 2020 I knew this was gonna happen. Some vehicles already interfere with the VINs. 86s have issues with journeys, 88’s have issues with compasses. But yes I have already seen the build sheet for it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 1, 2021 Share Posted January 1, 2021 This is what I frequently see when I type in the last 8: Real VIN: 1J7FJ26L4LL153078 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 5KK First American Title Insurance CO. ALA SE Decor Group ALK Italia Package APA Monotone Paint BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDQ 5-Speed Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana M235 Wide Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JJA Cigar Lighter K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAA Federal Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PS3 DOVER GRAY MET CC PRI PNT - HS3 QS3 DOVER GRAY MET CC SEC PNT - HS3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z84 Right Front Spring Group XIII Build date 10/4/89 Body code JL61 Link to comment Share on other sites More sharing options...
88mjsally Posted January 4, 2021 Author Share Posted January 4, 2021 More pics from this summer. This truck was in a bush when I found it Link to comment Share on other sites More sharing options...
jdog Posted February 9, 2021 Share Posted February 9, 2021 Selling Dealer: MONROE MOTOR COMPANY INC Monroe, NC Link to comment Share on other sites More sharing options...
