Hello all,
So just wanted to get some advice, I am currently working on my friends comanche, its a 89 Short bed 4.0 AW4 NP231J (New process)
Whats not awesome is the original 260k engine was burning oil, so last year of HS together, we pulled the drivetrain out, his dad had already pulled everything else out (wiring, manifolds, sensors, etc.) So now we have a rolling manche and we want to get it driving again!
So, the plan was, I gave him my old 4.0 out of my YJ (110k) and I was just going to use the HO exhaust manifold and make him a new exhaust and reuse all the renix components.
He does not want to uh, "permenently molest" the original wiring and all, so he wants to keep it renix.
So basically, if we are just using the 4.0 HO longblock and exhaust manifold. Does anyone see any issues that might arise with the renix junk?
If there is a stupid sensor that needs to be uh, persuaded to be bypassed. I will go to a pullyard with 6 renix XJs and pull whatever sensor plug it is and solder whatever resistor it needs to be happy lol.
The idea is to rebuild and swap back in eventually the renix. Just figured I'd ask since I am probably not the only one who is doing/done this.
Thanks.
HO INTO RENIX SWAP
This swap is easier than some will lead you to believe. And generally Pooh-poohed by those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block.
  • XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
  • 2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
  • YJ and 1997-1999 4.0L TJ blocks will interchange in XJ/ZJ
  • XJ/ZJ blocks, and the 2000+ TJ/WJ blocks do not interchange without significant modifications.
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
Now that we know which engines we can use, let’s get down to business.
The HO and Renix have some differences but none that can’t be overcome very easily.
One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from an HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head at the rear for the sender.
You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use a new Renix gasket. Exhaust ports are identical.
An alternative on exhaust manifolds:
As far as exhaust, you can use the Renix exhaust manifold and be fine.
If you want to use the HO exhaust manifold, you must go with an HO headpipe and screw your O2 sensor into that headpipe. Standard Renix harness is plenty long to do so.
A bung can be welded into the HO manifold to accept the EGR tube.
You will need to use your Renix distributor as it is different than the HO design. See Tips #12 – Setting Your 4.0 to #1 TDC and #13 – Distributor Indexing to be sure you get the distributor installed correctly.
The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications.
The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine.
As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case.
XJ: “Regular” (not Grand) Cherokees ’84-’01
ZJ: Grand Cherokee ’93-’98 (Gen1)
WJ: Grand Cherokee ’99-’04 (Gen2)
YJ: Wrangler ’87-’95 (Gen1)
TJ: Wrangler ’97-’06 (Gen2)
10-26-16
The others here pretty much covered the Renix bits you need to be concerned about, but I'll just mention that you'll need to swap all of the front end accessories from your MJ block over to the YJ longblock to get it all to play nice.  The waterpump/fan is offset in XJ/MJ's but centered on YJ/TJ blocks.  It's all plug and play though.  Careful you don't snap off any waterpump bolts.
9 hours ago, cruiser54 said:
HO INTO RENIX SWAP
10-26-16
20 hours ago, 89 MJ said:
This may help.
18 hours ago, Pete M said:
there are some older swap threads in the link in my sig. :L:
Thank you gentleman for all the posts. I am planning on dressing the engine with all the comanche components. Good thing I asked because we were just about to buy a HO manifold gasket lol
As for the sensors, I will neatly bypass the ones we don't need (Knock sensor) and tuck them away for the renix.
Thanks again!!
