Muncher Posted November 30, 2020 Share Posted November 30, 2020 Anyone know what these are for? One looks broken Link to comment Share on other sites More sharing options...
Ωhm Posted November 30, 2020 Share Posted November 30, 2020 3_pin looks like the Fog Lamp Switch. Link to comment Share on other sites More sharing options...
strictlyxjs Posted November 30, 2020 Share Posted November 30, 2020 Orange and black one (square) on bottom is for ash tray light. Top one (round) is and instrument bulb. Not sure on 3 prong. Isnt fog switch on left side of wheel? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 30, 2020 Share Posted November 30, 2020 Auto trans switch is on the right side in the same plug as fog and cargo. Link to comment Share on other sites More sharing options...
Muncher Posted November 30, 2020 Author Share Posted November 30, 2020 8 minutes ago, Ωhm said: 3_pin looks like the Fog Lamp Switch. That would make since why they weren't working then Link to comment Share on other sites More sharing options...
Muncher Posted November 30, 2020 Author Share Posted November 30, 2020 9 minutes ago, strictlyxjs said: Orange and black one (square) on bottom is for ash tray light. Top one (round) is and instrument bulb. Not sure on 3 prong. Isnt fog switch on left side of wheel? Instrument as in the gauge cluster ? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 30, 2020 Share Posted November 30, 2020 Yep, I work with those all the time for my dash switch systems. The 3 prong connect for to the back of a typical lit rocker switch. Can be used for fog, cargo, sports bar, and auto tranny switches. Center pin is load bottom is source and top is ground. The light socket look reusable. It takes a “74” bulb and twists in to the back of your switch panel housing. These are for the switches to the left and right of the steering column. Link to comment Share on other sites More sharing options...
strictlyxjs Posted December 1, 2020 Share Posted December 1, 2020 No its an intrument panel.light for the defrost switch. If you look at the other side there is a similar switch and bulb for the fogs/cargo light Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 1, 2020 Share Posted December 1, 2020 9 minutes ago, strictlyxjs said: No its an intrument panel.light for the defrost switch. If you look at the other side there is a similar switch and bulb for the fogs/cargo light I don't believe any MJ's came with defrost switches like the XJ's did. Those 3 pin connectors were used for quite a few of the different switch options. I've been collecting a small stack of them for use with my switch bezels and assemblies. Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 1, 2020 Share Posted December 1, 2020 yeah i have a swap xj harness in and use that rear defroster time relayed switch to run my rock lights. stays on for like 10 mins and only when key is on. i need bulbs so thanks for the number eh. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 1, 2020 Share Posted December 1, 2020 53 minutes ago, MiNi Beast said: yeah i have a swap xj harness in and use that rear defroster time relayed switch to run my rock lights. stays on for like 10 mins and only when key is on. i need bulbs so thanks for the number eh. So the switch itself is a timed delay off? So basically it can be switched on with the key and go off either with key off or after 10mins? Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 1, 2020 Share Posted December 1, 2020 26 minutes ago, ghetdjc320 said: So the switch itself is a timed delay off? So basically it can be switched on with the key and go off either with key off or after 10mins? perhaps but not sure. thinking its in a rely for delay. factory setup just ran wire to feed at body plug. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 1, 2020 Share Posted December 1, 2020 1 hour ago, ghetdjc320 said: I don't believe any MJ's came with defrost switches like the XJ's did. Now, supposedly there was a kit back in the day that would allow our MJ's to have rear defrost. I would imagine it was only for the solid windows and I am sure the XJ got the same kit as the windows are close in measurements. But in the Comanche Outfitters book(the red one) at the very back with all the accessories is a part number and description for a defrost kit. I have never seen a kit nor is there any as NOS. Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 1, 2020 Share Posted December 1, 2020 i have rear solid window but no heat bars. Link to comment Share on other sites More sharing options...
Muncher Posted December 2, 2020 Author Share Posted December 2, 2020 turns out the 3 pin wasn't for the fog lights but ill probably end up using it for my roll bar if i can find out where it goes Link to comment Share on other sites More sharing options...
Ωhm Posted December 2, 2020 Share Posted December 2, 2020 I forgot about this one since you don't have a automatic. Link to comment Share on other sites More sharing options...
