Has anyone tried to do anything with steel cable? I want to try to reproduce the Renix cruise control servo cable clips. But this would mean I need to either figure out how to dismantle the original cables or make new ones. And making new ones would probably be a better idea than trying to remove those crimps on the ends.
So what I’m trying to do is replicate these cables and replace the hooks too as I actually have one that is broken. I think I can do it myself, just an more curious about the crimp on the end.
Are you talking about the steel cable inside the sleeve from the cruise unit to the throttle body?  The one that pulls the throttle open?
Yes. I just posted a pic of what I’m trying to do.
You posted as I was typing.
It's not hard to find some kind of ferrule that you can crimp on with a crimping tool.  Getting them off is easy if you don't mind making the cable a little shorter.  Otherwise, you could cut off the existing ferrule and crimp a new one on.
I don't know what consequences there could be if I made that cable shorter other than it may not reach the throttle linkage. I also have some of the early 2.8L ones that I want to replace with the newer Renix style clips and give them longer cables as they are pretty damn short and mounting a 2.8L servo to reach say the 4.0L mount and the 2.5L mount can make some areas cramped.
If thats the name of that crimp thing then I will look into it!
Hmm... I wonder if you could solder them on instead of crimping them to avoid the high cost of the tool?
Like plumbing solder, I don't think you could get it hot enough with an iron.
10 minutes ago, derf said:
Solder won't hold up compared to a crimp.
Crimping is definitely better. Just thinking if there might be an alternative.
their isnt which is why they still crimp them. :nuts::roflmao:
