kaidenlem Posted October 21, 2020 Share Posted October 21, 2020 Just picked this up, 87 4.0 Auto short bed 4x4 Link to comment Share on other sites More sharing options...
jdog Posted October 21, 2020 Share Posted October 21, 2020 body: jh61 build date: 12-3-86 *X8 Cloth Low-Back Bucket Seats -Y1 DESCRIPTION NOT AVAILABLE ADA Light Group ADB Protection Group ADL Skid Plate Group AGI DESCRIPTION NOT AVAILABLE AHL Heavy Duty Insulation Group APA Monotone Paint AWE AWH Power Equipment Group BCQ 750 Amp Maintenance Free Battery CAC Low Back Bucket Seats CGW CKA Carpets - Floor and Cargo Area CUF Full Length Floor Console DGQ 4-Spd Automatic DMR 3.55 Rear Axle Ratio ERB 4.0L I6 MPI Engine GAC Tinted Glass Windows GFD Rear Sliding Window GPB HAA Air Conditioning HCC Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JFH Tachometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter LBB Courtesy Lamps LDA Underhood Lamp LMA Halogen Headlamps LNJ Front Fog Lamps LPE Cargo Lamp MBJ Black Front Bumper MCA Rear Body Color Applique MCB MDA Front License Plate Bracket MWB Sport Bar NAA Federal Emissions NHB Auxiliary Transmission Oil Cooler NHM Speed Control NMB Standard Duty Engine Cooling PXB QXB RAF AM/FM Cassette Radio SBA Power Steering SCG Leather Wrapped Steering Wheel SUA Tilt Steering Column TBB Full Size Spare Tire TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels XEA Tow Hooks XJH Lock Fuel Cap w/o Discriminator 3LX DESCRIPTION NOT AVAILABLE Link to comment Share on other sites More sharing options...
kaidenlem Posted October 21, 2020 Author Share Posted October 21, 2020 Too bad none of the original parts are left besides the 4.0, transmission, transfer case, and axles. There is absolutely no interior whatsoever and no dash Link to comment Share on other sites More sharing options...
Pete M Posted October 21, 2020 Share Posted October 21, 2020 9 hours ago, kaidenlem said: Too bad none of the original parts are left besides the 4.0, transmission, transfer case, and axles. There is absolutely no interior whatsoever and no dash that just means the possibilities are endless. Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 23, 2020 Share Posted October 23, 2020 This is a Chief. Link to comment Share on other sites More sharing options...
kaidenlem Posted October 27, 2020 Author Share Posted October 27, 2020 On 10/23/2020 at 11:31 AM, fiatslug87 said: This is a Chief. You would be correct. How rare is an 87 Chief? Link to comment Share on other sites More sharing options...
kaidenlem Posted October 27, 2020 Author Share Posted October 27, 2020 On 10/21/2020 at 5:39 PM, Pete M said: that just means the possibilities are endless. This is very true :) Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 27, 2020 Share Posted October 27, 2020 Chiefs are the highest trim you could get between 87-89 or 90? They are by far not common to stumble upon. Link to comment Share on other sites More sharing options...
Pete M Posted October 27, 2020 Share Posted October 27, 2020 higher than a Laredo? Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 27, 2020 Share Posted October 27, 2020 1 hour ago, Pete M said: higher than a Laredo? According to the body code chart, yes. I need to find a Laredo and see if it bears the H portion of the code. But I could’ve swore the Chief was advertised as the higher trim and then Chrysler knocked the chief out from being an option and Laredo became the highest. Link to comment Share on other sites More sharing options...
kaidenlem Posted October 27, 2020 Author Share Posted October 27, 2020 17 hours ago, eaglescout526 said: Chiefs are the highest trim you could get between 87-89 or 90? They are by far not common to stumble upon. 11 hours ago, Pete M said: higher than a Laredo? I had always thought that the Pioneer was the highest edition you could get... I do know that the early 2000's Jeeps used Laredo as the lowest trim package Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 Pioneer was an interesting one. You could get a pioneer with everything or nothing. Which makes sense because it would make you a pioneer in customizing your Jeep the way you want it. Laredo is being low is new to me so I have nothing in that. Link to comment Share on other sites More sharing options...
kaidenlem Posted October 28, 2020 Author Share Posted October 28, 2020 18 minutes ago, eaglescout526 said: Pioneer was an interesting one. You could get a pioneer with everything or nothing. Which makes sense because it would make you a pioneer in customizing your Jeep the way you want it. Laredo is being low is new to me so I have nothing in that. Interesting. I have an 87 LWD Pioneer with a mix of different options. The Laredo is the lowest trim package offered in the WJ Grand Cherokee is what I was referring to. Dig your nickname by the way Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 Yeah I have an 88 Pioneer that was pretty base aside from having a stereo system and power steering. So it could be had either way. I know the later Jeeps like the WJ have the Laredo as a lower package because theres the Overland trim that was the highest in its time and a few others for it. Thank ya! Link to comment Share on other sites More sharing options...
Pete M Posted October 28, 2020 Share Posted October 28, 2020 Pioneer was middle of the road. Link to comment Share on other sites More sharing options...
kaidenlem Posted October 28, 2020 Author Share Posted October 28, 2020 1 hour ago, eaglescout526 said: Yeah I have an 88 Pioneer that was pretty base aside from having a stereo system and power steering. So it could be had either way. I know the later Jeeps like the WJ have the Laredo as a lower package because theres the Overland trim that was the highest in its time and a few others for it. Thank ya! Gotcha, mine is fairly loaded down. I've got the 04 WJ Special Edition with all options, but it is still regarded as the Laredo. Either way, thanks for mentioning the Chief is fairly rare. Gave me a reason to keep her out of the scrap yard, she's not in decent shape anymore which sucks. She's been both picked over and neglected. Got my Eagle in November of 2018. Anyways, I'll include some pictures after this post. 12 minutes ago, Pete M said: Pioneer was middle of the road. Good to know I like both my 87's regardless of model, I can brag about them being the last few Jeep pickups made by AMC. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 5 minutes ago, kaidenlem said: Gotcha, mine is fairly loaded down. I've got the 04 WJ Special Edition with all options, but it is still regarded as the Laredo. Either way, thanks for mentioning the Chief is fairly rare. Gave me a reason to keep her out of the scrap yard, she's not in decent shape anymore which sucks. She's been both picked over and neglected. Got my Eagle in November of 2018. Nice! Hmm, I don't know much about the later years and their trim levels. Wish I did know more as they still could have the 4.0L. Yeah Chiefs do not pop up much and if it can be saved, it should. And congrats! I earned mine back in February 2013. I feel old thinking about that....so many things have changed since then. Link to comment Share on other sites More sharing options...
kaidenlem Posted October 28, 2020 Author Share Posted October 28, 2020 Link to comment Share on other sites More sharing options...
kaidenlem Posted October 28, 2020 Author Share Posted October 28, 2020 7 minutes ago, eaglescout526 said: Nice! Hmm, I don't know much about the later years and their trim levels. Wish I did know more as they still could have the 4.0L. Yeah Chiefs do not pop up much and if it can be saved, it should. And congrats! I earned mine back in February 2016. I feel old thinking about that....so many things have changed since then. It's not save-able as a daily, but I'm going to get it to run and drive as best as possible. It still has the entire 4x4 drivetrain and I plan to make it a rusty show pony, or even just to run into town for something. I only paid 120 bucks for it, with clean title in hand. I agree, many things have changed just since 2018. Glad I got mine when I did. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 Sounds like a good plan! I tried to edit my post before you could quote me but I hit 6 instead of 3. It was 2013 when I earned it. Alot still changed! Lol. I also got all my palms when I could before aging out. Tried to get the cooking MB before it became eagle required again too. Link to comment Share on other sites More sharing options...
Pete M Posted October 28, 2020 Share Posted October 28, 2020 I only got 2 palms. just ran out of time. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 Pete you have piqued my curiosity now. Link to comment Share on other sites More sharing options...
Torq_Shep Posted October 28, 2020 Share Posted October 28, 2020 Holy rust batman... Where did you find this? The bottom of the Dead Sea? Link to comment Share on other sites More sharing options...
kaidenlem Posted October 28, 2020 Author Share Posted October 28, 2020 1 hour ago, eaglescout526 said: Sounds like a good plan! I tried to edit my post before you could quote me but I hit 6 instead of 3. It was 2013 when I earned it. Alot still changed! Lol. I also got all my palms when I could before aging out. Tried to get the cooking MB before it became eagle required again too. 1 hour ago, Pete M said: I only got 2 palms. just ran out of time. My plan was after I got my Eagle I was going to focus more time on the Order of the Arrow, but life got busy and thoughts about doing so changed. I do wish I would've gotten some palms, but making Eagle was my main goal. Congrats to you and Pete both on working even harder to earn some palms. Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 28, 2020 Share Posted October 28, 2020 Hey aint nothing wrong with that at all! I posted a topic about this in the pub so we can pick up from there. Link to comment Share on other sites More sharing options...
