Southpaw Posted October 3, 2020 Share Posted October 3, 2020 I've Been Told that the Jeep trucks are rising in value only if they're four wheel drive.. I have an original two-wheel drive I would like to restore it as a two-wheel drive.. 87 Jeep Comanche Limited can anybody tell me why the two wheel drive don't have a value Link to comment Share on other sites More sharing options...
eaglescout526 Posted October 3, 2020 Share Posted October 3, 2020 Because most folks when getting a Jeep naturally expect it to be 4 wheel drive. So if they get a two wheel drive they will have to put in more work and effort to make it the truck they want vs the truck they can buy with 4 wheel drive. Don’t fret about that too much. The MJ is rising in value regardless of which wheel drive it is. I have a two wheel drive and I restored it and I love it. It’ll go just about anywhere it was designed to minus the situations where you would absolutely need 4 wheel drive. Link to comment Share on other sites More sharing options...
NHMJXJ Posted October 3, 2020 Share Posted October 3, 2020 I would echo Eaglescout526 that there's an expectation a Jeep will be 4WD. Personally, I wouldn't buy a Jeep that wasn't 4WD (again). Had this very conversation with @HOrnbrod whose truck you see in the banner. A beautiful 2WD. I live in New England, so 4WD is a nice thing to have. As to value? Regardless of equipment, there's an a$$ for every seat, so the value is relative to condition, region, desire and deep pockets. Link to comment Share on other sites More sharing options...
Southpaw Posted October 4, 2020 Author Share Posted October 4, 2020 7 hours ago, eaglescout526 said: Because most folks when getting a Jeep naturally expect it to be 4 wheel drive. So if they get a two wheel drive they will have to put in more work and effort to make it the truck they want vs the truck they can buy with 4 wheel drive. Don’t fret about that too much. The MJ is rising in value regardless of which wheel drive it is. I have a two wheel drive and I restored it and I love it. It’ll go just about anywhere it was designed to minus the situations where you would absolutely need 4 wheel drive. Thanks I was looking at the gas mileage they say the 87 six cylinders got about 20 miles to the gallon plus with the ground clearance and maybe adding a winch should should go a lot of places thanks again for the response Link to comment Share on other sites More sharing options...
Dzimm Posted October 4, 2020 Share Posted October 4, 2020 I wouldn't read too much into value of 2wd vs 4wd. Overall condition of the truck is getting more important than anything else but 4wd can help make it sell faster. As far as gas mileage, a 2wd with manual trans will typically give you the best results with less spinning mass and manual shifts. Really though, I got the same 18-22mpg in my lifted 97+ swap 4.0 AW4 as I did with my 92 4.0 AX-15 when it was stock. Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 On 10/3/2020 at 12:37 PM, eaglescout526 said: Because most folks when getting a Jeep naturally expect it to be 4 wheel drive. So if they get a two wheel drive they will have to put in more work and effort to make it the truck they want vs the truck they can buy with 4 wheel drive. Don’t fret about that too much. The MJ is rising in value regardless of which wheel drive it is. I have a two wheel drive and I restored it and I love it. It’ll go just about anywhere it was designed to minus the situations where you would absolutely need 4 wheel drive. Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 Thanks for the info I'm hoping to have a nice little Cruiser / hunting rig when I'm done if I ever get done Link to comment Share on other sites More sharing options...
derf Posted October 6, 2020 Share Posted October 6, 2020 32 minutes ago, Southpaw said: Thanks for the info I'm hoping to have a nice little Cruiser / hunting rig when I'm done if I ever get done Lesson #1 with Jeep projects. They are never done. Link to comment Share on other sites More sharing options...
89 MJ Posted October 6, 2020 Share Posted October 6, 2020 44 minutes ago, Southpaw said: Thanks for the info I'm hoping to have a nice little Cruiser / hunting rig when I'm done if I ever get done Honestly, I don't think I would convert a 2wd truck to 4wd. If you live in the rust belt, you shouldn't drive the truck in the winter because they are rare and climbing in value, and if you live in the south, you won't probably need 4wd for the snow. There are quite a few people in AZ that do mild wheeling with their 2wd trucks. Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 4 hours ago, 89 MJ said: Honestly, I don't think I would convert a 2wd truck to 4wd. If you live in the rust belt, you shouldn't drive the truck in the winter because they are rare and climbing in value, and if you live in the south, you won't probably need 4wd for the snow. There are quite a few people in AZ that do mild wheeling with their 2wd trucks. Yep I live in Michigan where rust is the favorite color hopefully I'm going to pull this down to the frame and clean it up I would like to keep it two wheel drive the ground clearance will be a big help Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 On 10/3/2020 at 2:14 PM, NHMJXJ said: I would echo Eaglescout526 that there's an expectation a Jeep will be 4WD. Personally, I wouldn't buy a Jeep that wasn't 4WD (again). Had this very conversation with @HOrnbrod whose truck you see in the banner. A beautiful 2WD. I live in New England, so 4WD is a nice thing to have. As to value? Regardless of equipment, there's an a$$ for every seat, so the value is relative to condition, region, desire and deep pockets. Thanks for the info Link to comment Share on other sites More sharing options...
dasbulliwagen Posted October 6, 2020 Share Posted October 6, 2020 I'm sure as you know living in Michigan, driving ability matters more than having 4wd in the winter. I spent the first 28 years of my life there and never had a 4wd, and rarely got stuck..... I take that back, I did have a Grand Wagoneer for a little while toward the end. That thing was a tank through the snow! Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 Just now, dasbulliwagen said: I'm sure as you know living in Michigan, driving ability matters more than having 4wd in the winter. I spent the first 28 years of my life there and never had a 4wd, and rarely got stuck..... I take that back, I did have a Grand Wagoneer for a little while toward the end. That thing was a tank through the snow! Yep we just make sure we had some friends with us and some shovels and we actually used wood ash from the wood stove every time we got stuck but I plan on moving the Missouri once my house sells and if I'm able to get this thing rebuilt it will never see the snow just a few two tracks to and from my bow stand hopefully this thing is really clean I'm not used to being able to take bolts out without torches and grinders and break away it's a whole different world Link to comment Share on other sites More sharing options...
Southpaw Posted October 6, 2020 Author Share Posted October 6, 2020 On 10/4/2020 at 12:47 AM, Dzimm said: I wouldn't read too much into value of 2wd vs 4wd. Overall condition of the truck is getting more important than anything else but 4wd can help make it sell faster. As far as gas mileage, a 2wd with manual trans will typically give you the best results with less spinning mass and manual shifts. Really though, I got the same 18-22mpg in my lifted 97+ swap 4.0 AW4 as I did with my 92 4.0 AX-15 when it was stock. this truck seems really clean . the interior is wrecked but the Body and frame her an excellent condition .the lady I bought it from was the original owner said it ran good when she parked it just leaked a lot of oil which I believe is the rear main some guy pulled the head off and left it off so it's been sitting ever since. 178000 original miles been sitting since 2012 under a carport Link to comment Share on other sites More sharing options...
