Muncher Posted July 31, 2020 Posted July 31, 2020 Alright so another question for today is window related. So on my driver's side i rolled it down and then it just wouldn't go up so i had to push it up my self. And on the passenger side it goes down but then at like 4 inches of window left it dosent go down anymore. Any tips to fix this?
rylee144 Posted July 31, 2020 Posted July 31, 2020 Mine just needed WD40. Got the bottle with the bendable spray nosle. Took off the door card and bent the nosle to the track and gave it a spray while cranking the window up and down. It may help it may not. Mine has been perfect ever since
Muncher Posted July 31, 2020 Author Posted July 31, 2020 7 minutes ago, rylee144 said: Mine just needed WD40. Got the bottle with the bendable spray nosle. Took off the door card and bent the nosle to the track and gave it a spray while cranking the window up and down. It may help it may not. Mine has been perfect ever since Ill have to try that. Not sure why the drivers side didnt go back up though
rylee144 Posted July 31, 2020 Posted July 31, 2020 Me either. I'm no master. But when you have the door card off you'll be able to see better and check your speakers.
eaglescout526 Posted July 31, 2020 Posted July 31, 2020 I discovered this as I'm sure others did and its probably been mentioned but if you look down in the door you will see a hose. That hose holds the snake when the window is rolled down. Spray in there and roll it up and down a few times to help lube the track up
Muncher Posted August 1, 2020 Author Posted August 1, 2020 1 hour ago, eaglescout526 said: I discovered this as I'm sure others did and its probably been mentioned but if you look down in the door you will see a hose. That hose holds the snake when the window is rolled down. Spray in there and roll it up and down a few times to help lube the track up The hose was just laying in my door.
Muncher Posted August 1, 2020 Author Posted August 1, 2020 I did try to lube them but that didnt work. So the passanger side goes up ajd down fine but when it gets to the bottom it comes off the track and i have to put it up my self. And oj the passanger side the handle just spins at a certain point and it won't go down. Not quite sure how to fix this.
Muncher Posted August 1, 2020 Author Posted August 1, 2020 4 minutes ago, eaglescout526 said: Yep. That’s where it lays. Also i believe the hose wasn't connected to anything. Is t suppose to be?
eaglescout526 Posted August 1, 2020 Posted August 1, 2020 It should be connected some where on the regulator.
Muncher Posted August 1, 2020 Author Posted August 1, 2020 1 minute ago, eaglescout526 said: It should be connected some where on the regulator. That's where the crank is right?
eaglescout526 Posted August 1, 2020 Posted August 1, 2020 If it wasnt such a task to take my door cards off I could show you. But it should be somewhere around there.
jdog Posted August 1, 2020 Posted August 1, 2020 38 minutes ago, Muncher said: the handle just spins at a certain point and it won't go down. needs regulator rebuilt or replaced, fairly easy process and I recommend using 1994 to 96 regulator as they bolt in instead of rivets. I would use white lithium grease in a spray can instead of wd-40. I believe minuit rebuilt his when he did a power window swap
Minuit Posted August 1, 2020 Posted August 1, 2020 35 minutes ago, jdog said: needs regulator rebuilt or replaced, fairly easy process and I recommend using 1994 to 96 regulator as they bolt in instead of rivets. I would use white lithium grease in a spray can instead of wd-40. I believe minuit rebuilt his when he did a power window swap I think I did a separate write-up of it somewhere. I'll look for it here in a bit. The gist of it is, if the regulator skips, it's probably too late, but if it's stiff or moves slowly, cleaning and lubing the worm gear will make a world of difference.
Muncher Posted August 1, 2020 Author Posted August 1, 2020 1 hour ago, Minuit said: I think I did a separate write-up of it somewhere. I'll look for it here in a bit. The gist of it is, if the regulator skips, it's probably too late, but if it's stiff or moves slowly, cleaning and lubing the worm gear will make a world of difference. I think its to late then
