derf Posted July 26, 2020 Share Posted July 26, 2020 I've been tinkering on my XJ for a few years now. It's my second XJ. My first one was my daily driver back when it was new. This one is a 2001. It has a Rubicon Express 3" lift and 265/75R16 tires on cheap Quadratec wheels. The original axles are gone. The XJ Dana 44 I swapped in has 4.56 gears, a Truetrac, and disc brakes. The front high pinion XJ Dana 30 I swapped in has 4.56 gears and a Truetrac. It's a 4.0 auto with the 242 transfer case. With the limited slip and full time high range it makes a nearly unstoppable winter beater. The tires rub off road though so I started installing some bushwhacker flat cutout flares to make room. They cover the tires well and transition nicely into the JCR bumper and rock sliders. Link to comment Share on other sites More sharing options...
derf Posted July 26, 2020 Author Share Posted July 26, 2020 I'm also working on replacing the o-rings on the oil filter adapter as well as a couple of other leaks. I also have to get the shift linkage sorted out. It doesn't have enough range to fully engage 4lo. So I'm going to look at linkage bushings and maybe tweaking the shifter to allow some more throw. Link to comment Share on other sites More sharing options...
mjeff87 Posted July 26, 2020 Share Posted July 26, 2020 Another cardboard guy. I'm lucky enough to work in a distribution warehouse, and have an endless supply of slip sheets and other large sheets at my disposal. Link to comment Share on other sites More sharing options...
Pete M Posted July 26, 2020 Share Posted July 26, 2020 me too! double thick cardboard is just the perfect blend of padding and disposable. plus provides short term protection against those little biting ants that are all over the driveway Link to comment Share on other sites More sharing options...
derf Posted July 27, 2020 Author Share Posted July 27, 2020 I wanted a fresh surface to tell me what all was leaking. I figured the cardboard would make that easier. And it helps when you pull the oil filter adapter and oil drips everywhere. It'll go away when I'm done with current repairs. Link to comment Share on other sites More sharing options...
Pete M Posted July 27, 2020 Share Posted July 27, 2020 yup, the absorbancy factor is awesome Link to comment Share on other sites More sharing options...
89 MJ Posted December 18, 2020 Share Posted December 18, 2020 I really wanted a set of flares like this for my blue truck, but they didn't make ones for the MJ. I do like the looks of them though. Link to comment Share on other sites More sharing options...
derf Posted December 18, 2020 Author Share Posted December 18, 2020 Yeah, I like the look over the other flares they offer. I wonder if they will ever make the rear flares to match for the 2DR XJ/MJ. Link to comment Share on other sites More sharing options...
89 MJ Posted December 18, 2020 Share Posted December 18, 2020 On 12/18/2020 at 2:36 PM, derf said: Yeah, I like the look over the other flares they offer. I wonder if they will ever make the rear flares to match for the 2DR XJ/MJ. Expand I think they make some for the 2 door XJ, but I read (on CC I think) that they did not fit the MJ quite right. Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2020 Share Posted December 18, 2020 On 12/18/2020 at 2:38 PM, 89 MJ said: I think they make some for the 2 door XJ, but I read (on CC I think) that they did not fit the MJ quite right. Expand stock 2dr flares will not match up on an MJ. but aftermarket flares seem to be more universal so there's a chance. Link to comment Share on other sites More sharing options...
89 MJ Posted December 18, 2020 Share Posted December 18, 2020 On 12/18/2020 at 3:39 PM, Pete M said: stock 2dr flares will not match up on an MJ. but aftermarket flares seem to be more universal so there's a chance. Expand You know, sometimes I think that it was a dumb idea to not have either the XJs share flares or the 2 door XJ and the MJ to share rear flares. Then I remember, these were designed by AMC, expect stupid. Cool, but still kinda dumb. Link to comment Share on other sites More sharing options...
derf Posted January 21, 2021 Author Share Posted January 21, 2021 The 4.0 in this rig has a rod knocking. So I'm starting the rebuild of a donor engine. Both my XJ and the donor engine have the 0331 head that tends to crack. I found an 0331 TUPY head and it showed up today. Time to start the teardown and evaluation of the donor. I haven't decided if I'm going to stroke it while it's apart but I will soon. Link to comment Share on other sites More sharing options...
jdog Posted January 21, 2021 Share Posted January 21, 2021 Stroke it, stroke it (maybe I'm the only one singing it) Link to comment Share on other sites More sharing options...
derf Posted January 21, 2021 Author Share Posted January 21, 2021 That's what I'm leaning towards. Link to comment Share on other sites More sharing options...
All around mj Posted January 21, 2021 Share Posted January 21, 2021 It is ultimately up to you, but if it is in the budget I vote... stroke it. Link to comment Share on other sites More sharing options...
