OMG The Crewcab 6x6 Comanche
5 hours ago, 89 MJ said:
Also, for you bed, maybe look into taking two beds and cutting one right behind the wheel opening and the other in front of the wheel opening. Then you won’t need to worry about making sure the wheel opening lines up. That is unless you just stretch the stock one in the middle.
Here is a a pic of what I’m thinking the best way to do your door would be. Not an MJ, but still relevant. Check out the rear door, except you would section the front of the XJ window opening in the front of the MJ door.
The bed plans for this truck (dealing with a short bed) is to as mentioned - build it to a factory long bed length. This way i can still use an MJ long bed topper on it if i ever want to vs dealing with some oddball bed length. My cutting plan is the cut in the middle of the wheel well opening, a couple inches in front of the fender flare and also a couple inches behind the fender flare. So my bed will then be sectioned into a front - a front of wheel well - a back of wheel well - then a rear. Keeping a few inches of tire clearance on either side i may only need to make filler for the middle of the bed above the wheel well(s) I can disect a photo to explain later.
Today was gonna be my day to chop the shell up and start inching it closer to the MJ rear section but it was a wicked hot day out with the MI humidity so instead i flipped on the AC in the garage and got back into that tcase.
The tcase took a little puzzle work but i got it all buttoned up this morning. The input(s) ride on a ball bearing thats pretty easy to install. Tap bearing into case - slide input shaft through bearing - install yoke - finished!
The E-tape on the pictured input shaft is to keep the thrust washer tight to the gear because when the shaft falls over and the gear slides over on the shaft, ALL the needle bearings fall out. This only happened once thankfully.
thumbnail_resized_20200620_140922_28483f
More loose needle bearings that sit inside the output. I was worried about how well they would line up when installing the output side but these were cake. For those that don't know these are considered pilot bearings and the very bottom of the shaft thats pictured above is the pilot that rides on those bearings.
thumbnail_resized_20200620_143526_a21ebc
Just about finished up after snugging this one down and as i reached across my bench to grab a cotter pin the nut let go and exploded. I couldn't find the 3rd piece but these 2 didn't go too far. What a bummer!
thumbnail_resized_20200620_135835_21ec6c
You can see the old dirty side vs the shiny side... this tells me this nut has been split for a little while now. It had me concerned the others might also pop but once i noticed the color difference i realized what was really going on here. I've read that Deez Nuts are hard to come by but supposedly they are the same as a Dana 35 pinion nut. Lucky me the axle still bolted in under the rear of the truck is a Dana 35 and the nuts still there. I'll be confirming this soon.
thumbnail_resized_20200620_145755_8d9e87
Installed the shift rail seals and rubbed all my greasy hand prints off the unit. Looking pretty good if you ask me!
thumbnail_resized_20200620_145246_85513a
thumbnail_resized_20200620_145254_268338
Time for some body progress! Mapped out my cuts with plenty of material to spare. I will peck away at the not needed material once i get the lines figured out between the 2 halves.
thumbnail_resized_20200624_174228_274b47
Dropped it like its hot and let the bodies hit the floor!
thumbnail_resized_20200624_181218_15da27
thumbnail_resized_20200624_183827_a82f8c
Didn't care for the look of that roof so i chopped some more off the top. The roof height difference is no joke! I did save the old chunk of roof and i'm gonna try to make it fit without trimming the inner structure but if i have no luck - its getting cut some more for sure.
thumbnail_resized_20200629_173246_9cf28a
thumbnail_resized_20200629_173851_aba7ed
thumbnail_resized_20200629_203346_1e40a8
Floor is a darn mess! For the time being just to get things rolling i cut out the top of the frame rail 6" in either direction. The MJ frame got cut just 1"~ in front of the front crossmember nut/stud. The XJ frame got cut at a seam line just about middle of the B-pillar.
thumbnail_resized_20200629_203248_ac3622
Slowly working the 2 hafs together cut by cut its getting closer! Soo to my surprise these 2 halfs are actually coming together fairly simple. I won't elaborate too many specifics as some of these things need to be left a surprise for those who chose to attempt their own crewcab build.
thumbnail_resized_20200629_203324_13a9eb
Stay tuned!
The roof rack is something thats been on my mind and I've tempted planning that into the final result of the build BUT in the sense of trying to make this look clean (as I can) and challenging myself vs a quick patch job. I'm going for a presentable roof without one mounted.
Here we go,
After 4 hrs tonight we have a near close enough fit for some welds finally
thumbnail_resized_20200701_195457_a2c9ea
I'll interrupt your viewing for this disclaimer - I was faced with a dilemma, Either decision would contradict the other... It was either to keep the high body line (just below the door handle) true and have a slightly off rocker-frame rail OR it was keeping the rocker-frame straight and having to move metal to get the body line back to make it look right. I chose to keep the body line and modify the rocker-frame as those will need attention regardless.
So you may also be wanting to point out that the rear door is overlapping some - i got this no worries...
thumbnail_resized_20200701_195533_bc8de4
thumbnail_resized_20200701_205539_33f4d2
Should have some more progress pics tomorrow, aiming for having it sitting on its own weight!
Time to tackle this door sill. So with favoring the body line over the rocker alignment meant this had to be moved only about 1/4". This wasn't too difficult as i split it from in the inside of the rocker, placed where it was desired for alignment, marked the line for where it will now rest, cut and welded back in place.
thumbnail_resized_20200702_134334_92116b
106422371_306054930444113_19100802644657
Now it was time for some rocker slider action! dual purpose this will also strengthen up the body and tie into the frame. I didn't however call my measurement correctly and shorted myself about 8" of material. My plan was to run this slider all the way out the back of the cab, which will still happen i will just need to add a chunk later on :/
thumbnail_resized_20200702_134306_670fdc
The slider does taper into the body the further it goes towards the rear - thats the nature of how i've been doing my sliders because i like them butted up to the inside of the rocker where it meets the floor and gets seam welded there. The rear door isn't shut all the way because i still have the braces in place so it looks worse than it is.
thumbnail_resized_20200702_174742_399836
thumbnail_resized_20200702_181039_c46392
thumbnail_resized_20200702_181154_678a9b
I didn't get it pictured but this thing is sitting on its own weight now, no jack stands, just flat tires hahaha. The joining of the 2 unibody frames, door sill adjustment(driver side), welding the inside of the "new" C-pillars together and driver rock slider getting welded in took all day. SOO MUCH WELDING!
Though the last week had been Brutal with the heat and i didn't get much done I did manage to get the passenger side rock slider welded in tonight. Tires aren't the best and neither is my compressor - mainly just used to pump up tires occasionally so i snuck the jack in there while i weld the underside seam.
With the last scrap haul from the leftover bits of front half MJ and etc i scored some more budget $ and stopped by the steel yard for some steel plate to cut my frame stiffener's. I figure that's next on my list of to-do's.
I'll be honest here - I'm kinda dreading the roof line :O Soo maybe after i'm sick and tired of laying on my creeper to wire wheel/grind and weld in those frame stiffeners I suppose i'll stretch my legs a bit and get the roof over with and maybe pickup this garage some.
thumbnail_resized_20200708_200111_e95338
  • 1 month later...
annnnnnnnnd that's why I haven't moved it to Epic just yet.  many have started, few have finished. :(  It's a gigantic undertaking and life can easily get in the way.  but maybe he can find a buyer that can give the truck some fresh enthusiasm.  :L:
