2 hours ago, ajwyble said:
Does anyone know where I can find an ecm for a 87' commanche?
Ebay is your friend here.
On 11/13/2016 at 6:11 PM, Ωhm said:
I believe the manual ECU has a more aggressive spark advance curve, then the auto. Since you can wind up a manual trans.
most automatics cap the rpms and cut the power during shifts, not sure if MJ´s do it, how much communication is there between the ECU and the TCU?
none
Recent posts split.
ajwyble, it makes no sense to ad a post looking for a part at the end of a four-year old discussion.
:hijack:
To keep this going alittle longer what’s the verdict on using a later model ECU in a 86 2.5? And does the 4.0 and 2.5 share ECU’s? Meaning there interchangeable.
Wouldn’t think so but why not ask
The 2.5 and 4.0 are different animals.  Not compatible.
BTW - what happened to the OP that re-started this thread?
Thanks, figured that was the case just needed a confirmation from the experts.
