AMCJeepMJ Posted April 26, 2020 Share Posted April 26, 2020 1975 Ford Econoline 150 Chateau mini-camper. 351 Windsor, 2bbl carb, auto trans. 1st year for this body style. Picked this monstrosity up a few days before Christmas 2019; had been sitting in tall grass at a relative by marriage''s property since 2008 with a bad transmission. Mice had made a mess of the camper portion, and a broken window allowed wasps to build homes and let a decade of Oregon weather inside. Purchase cost was the cost of a tow across town. Purchased new by my wife's grandparents and subsequently owned by my wife's uncle from whom we picked it up. Since the first of the year, I have replaced the fuel tank, fuel lines, fuel pump, put new wheels/tires on it, had the trans rebuilt, and stripped the bio-hazard bed/cabinets/stove/fridge/water closet/carpet/veneer. Propane tank and lines also came out. Re-registered it as a passenger vehicle instead of a motor home, and now is reasonably road-worthy. Still have to refresh the suspension/steering and do some brake work, as well as re-upholster the front swivel seats and fix the broken driver seat base. Then to figure out what to do with the rear of the van. It needs sidepipes. Definitely sidepipes. Current exterior, interior before, and interior current pics attached. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted April 26, 2020 Author Share Posted April 26, 2020 Round headlights are best headlights. Link to comment Share on other sites More sharing options...
neohic Posted April 26, 2020 Share Posted April 26, 2020 I dig it. Link to comment Share on other sites More sharing options...
89 MJ Posted April 26, 2020 Share Posted April 26, 2020 I like it! Link to comment Share on other sites More sharing options...
Pete M Posted April 26, 2020 Share Posted April 26, 2020 neat! is it now a cargo van or do you plan on making it a camper again? are the rear doors regular height or do that go up in to the cap? Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted April 26, 2020 Author Share Posted April 26, 2020 She does have minor rust on her from where the water tank and sink leaked and sliding door weatherstripping failed, below where the cabinetry was located. Coroseal has done a fine job of neutralizing the rust, but I still need to get underneath with a mini roller. Two small holes from rust exist in the rear floor; these will have to be addressed as well as the circular hole cut from where the commode previously was mounted. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted April 26, 2020 Author Share Posted April 26, 2020 3 minutes ago, Pete M said: neat! is it now a cargo van or do you plan on making it a camper again? are the rear doors regular height or do that go up in to the cap? Man, I wish it had the tall doors as they would be AWESOME; they are the regular height regretfully. As it is, she can be used as a cargo van; the wife wants a 2x4 bed build in the back so that means putting in carpet/padding, and re-paneling the walls. We already have new curtains made for it as the previous were sun faded and wouldn't re-dye. The house electrics, fuse panel, transformer, and wiring were pulled as I don't trust the 45 year old electrics in it... don't want to burn the thing down by plugging it in with an extension cord. I have schematics for a deep cell battery powered system with solar charger saved for later implementation. Link to comment Share on other sites More sharing options...
trailseeker Posted April 28, 2020 Share Posted April 28, 2020 Great stuff you got there. I'm considering replacing headlights right after I'm done installing my nerf bars. I just need to find the right LED lights that I'll be using . Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted April 29, 2020 Author Share Posted April 29, 2020 Starting and idling issues have been narrowed down to the carb; have my eye on a Holley 500 cfm electric choke 2bbl model to replace the ancient Autolite/Motorcraft that is on it now. Not cheap at 400+, but cheap as far as performance go. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 9, 2020 Author Share Posted May 9, 2020 Well, while waiting on the Holley to arrive, got the rear doors swapped out from a 1991 E-250. Not a color match but at least she won't leak. Factory privacy glass is a plus. Link to comment Share on other sites More sharing options...
Pete M Posted May 10, 2020 Share Posted May 10, 2020 color matching is overrated when you have a white boat upside down on your roof Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 10, 2020 Author Share Posted May 10, 2020 23 hours ago, Pete M said: color matching is overrated when you have a white boat upside down on your roof Right?!? It drives and handles like an old boat as well. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 10, 2020 Author Share Posted May 10, 2020 Spare tire carrier went onto the right door, and both doors received a realignment. Link to comment Share on other sites More sharing options...
mjeff87 Posted May 13, 2020 Share Posted May 13, 2020 Shaggin' Wagon, I dig it. Needs sidepipes, agreed, plus a Mystery van paint job and you're set. LOL. Keep us posted on progress Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 17, 2020 Author Share Posted May 17, 2020 Threw some E3 plugs in and installed the 500 cfm Holley 2bbl carb. Still need to adjust the kickdown linkage but she starts right up and idles like a champ. The Motorcraft carb had a vacuum actuated choke; the Holley is electric. This is my first attempt at an aftermarket carb switcharoo; looks like I didn't booger it up too much. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 17, 2020 Author Share Posted May 17, 2020 Purring like a 45 year old kitten with leaky valve covers. Holley_500_2V.mp4 Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted May 24, 2020 Author Share Posted May 24, 2020 Valve cover gaskets addressed and valve covers cleaned up. Voltage regulator failed so it became time to give the old girl a replacement alternator as well. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted June 13, 2020 Author Share Posted June 13, 2020 Final update: Had a mobile dog groomer randomly knock on the door on Monday asking if the van was for sale... two days and 3800.00 later and she was gone. Sidepipes had just arrived too, never got a chance to install them. Link to comment Share on other sites More sharing options...
Pete M Posted June 13, 2020 Share Posted June 13, 2020 dang that was fast! easy come, easy go I guess. Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted October 16, 2020 Author Share Posted October 16, 2020 Ya, it sure was. Wasn't expecting for it to turn over so quickly. Just broke even on it, too. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 16, 2020 Share Posted October 16, 2020 On 6/12/2020 at 11:24 PM, AMCJeepMJ said: Final update: Had a mobile dog groomer randomly knock on the door on Monday asking if the van was for sale... two days and 3800.00 later and she was gone. Sidepipes had just arrived too, never got a chance to install them. side pipes? Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted October 16, 2020 Author Share Posted October 16, 2020 7 hours ago, MiNi Beast said: side pipes? Yessir! Patriot 80" side pipes from Summit. With the 139" wheelbase they would have fit perfectly. I am glad I never pulled the trigger on the Hooker long tube headers I was eyeballing. Link to comment Share on other sites More sharing options...
MiNi Beast Posted October 16, 2020 Share Posted October 16, 2020 so what you going to do with them now? Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted October 16, 2020 Author Share Posted October 16, 2020 2 minutes ago, MiNi Beast said: so what you going to do with them now? They went with the van sale; new owner's husband is a Ford guy and allegedly was to put them on... I haven't seen the van around town... not that I actually get out any more these days, so who know if he put them on. Link to comment Share on other sites More sharing options...
