WhiskeyBravoXJ Posted April 24, 2020 Share Posted April 24, 2020 89 Comanche 4.0L AW4 NP231 Dana 30 / 44 SWB Shreveport, LA 'Merica All door sticker info lost to time I think it was a dark blue metallic color originally (based on doorjambs, but not sure due to multi-colored panel replacement on top of super-oxidized clear coat). Currently black Rustoleum rattle can primer. Had SporTruck decals, not sure if they belonged there. Light bar works left of the glovebox latch. 1 self retaining Dakota taillight. No rust, a few minor dents from PO's play time. Rear bumper MIA, brackets KIA. Interior is a blue vinyl, appears to be all original. Bench seat, column shift, manual windows, sliding back plexiglass, and 3 rifle gun rack (that was a factory option, right?) When I got this heifer it had 33x12.50r15s (15x8 F/ 15x9 R), 4.5" coil springs / leaf springs , shocks, tube LCAs, factory track bar, death wobble, and a full-time EGR valve (6" vac hose valve to manifold lol) I added a RC drop track bar and dual steering stabilizers, Rustys steering box braces, ZJ tierod, Alloy ball joints, working master and wheel cylinders, a loud @$$ flowmaster, and a P/S pump or 10 She was passed around a lot before it ended up in my hands (traded straight up for 2000 Saturn SL). Still working on her, but got really curious if the 4.0 auto 4wd D44 combo was factory Link to comment Share on other sites More sharing options...
jdog Posted April 24, 2020 Share Posted April 24, 2020 9/14/88 build date body-MJJL61 *X2 DESCRIPTION NOT AVAILABLE -Q8 DESCRIPTION NOT AVAILABLE ADL Skid Plate Group BAYP 105 Amp Alternator BCYP 95 Amp Battery CBAP Straight Back Bench Seat DGB All 4-Speed Automatic Transmissions DHTP Elec,Shift-on-the-Fly,P/Time T/Case DRKP Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAAC All Engines EAFC 1.4L I4 16V MultiAir Turbo Engine ERB 4.0 Engine GFD Rear Sliding Window GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning PQ9 DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RAB AM/FM Radio RCDP 4 Speakers SBAA Power Steering TAAC All Tires TBB Full Size Spare Tire TNCA P195/65R15 BSW AS Touring Tires XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield XEUP Front Suspension Skid Plate YGGA 9 Additional Gallons of Gas Z01P Rear Spring Group I Z67P Left Front Spring Group XVI Z86P Right Front Spring Group XV 4HC Special Scheduling Condition III 5ALA DT-Vehicle Family APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CKJS Black Vinyl Floor Covering CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KDCS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS Bright Windshield Moldings MMCS Rear Door Solid Window Insert MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS Underground Calibration NBKS EVAP Control System NDAS Catalytic Converter NF2S 18.5 Gallon Fuel Tank QQ9S DESCRIPTION NOT AVAILABLE SCBS Perforated Steering Whl w/Red Stitch SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels WMCS Open XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 165S Zone 65-New Orleans Link to comment Share on other sites More sharing options...
WhiskeyBravoXJ Posted April 25, 2020 Author Share Posted April 25, 2020 Thanks for the info. I wish I understood more of it. Looks like it had some good options underneath. Any ideas how I could determine the original color code and trim level? I read somewhere on here that VIN 2 was a base/SporTruck, but not sure. PS - I apologize for me and Jose writing a novel about the ole girl. - another mechanic named Jason Link to comment Share on other sites More sharing options...
Pete M Posted April 25, 2020 Share Posted April 25, 2020 the 6th digit indicates the trim level and yes, a 2 means base. but since you could order just about anything on a base, that alone doesn't mean much (as your truck testifies since it is simply decked-out with goodies! Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 25, 2020 Share Posted April 25, 2020 For the color code look at the tag above the master cylinder, code is circled in the picture. Link to comment Share on other sites More sharing options...
89 MJ Posted April 25, 2020 Share Posted April 25, 2020 Nice truck! I think your grille is upside down. Link to comment Share on other sites More sharing options...
JMO413 Posted April 25, 2020 Share Posted April 25, 2020 *X2 TRIM STYLE X2 - VINYL BENCH -Q8 165 Zone 65-New Orleans 1AA U.S. Dealer Retail 4HC Special Scheduling Condition III 5AL Low Series Tracking ADL Skid Plate Group APA Monotone Paint BAY 105 Amp Alternator BCY BATTERY, 58-475 CC BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRK Dana 44/226MM Rear Axle DSA Anti-Spin Differential Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB MOPAR Hood Lock K3Z STRIPE/BADGE/MOLDING/COLOR KDC LAF Seat Belt Alert-Driver Seat only LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PQ9 DRK BALTIC BLUE M CC PRIMARY PAINT - HQ9 QQ9 DK BALTIC BLUE MCC SECONDARY PAINT - HQ9 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCB Perforated Steering Whl w/Red Stitch SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z67 Left Front Spring Group XVI Z86 Right Front Spring Group XV Link to comment Share on other sites More sharing options...
WhiskeyBravoXJ Posted April 25, 2020 Author Share Posted April 25, 2020 Thanks for all the info. I might try to get it back to the factory color if possible. The door jambs look pretty sexy when the sun hits it right. Now I'm gonna go hide from shame. In 3 years I never noticed the grille Link to comment Share on other sites More sharing options...
Pete M Posted April 26, 2020 Share Posted April 26, 2020 On 4/25/2020 at 8:29 PM, WhiskeyBravoXJ said: Now I'm gonna go hide from shame. In 3 years I never noticed the grille Expand not the first, won't be the last truck looks fantastic either way Link to comment Share on other sites More sharing options...
jdog Posted April 1, 2021 Share Posted April 1, 2021 Selling Dealer: REGENCY JEEP EAGLE OF ALEXANDRIA Alexandria, LA Link to comment Share on other sites More sharing options...
